Old 08-20-2015, 05:39 PM   #1
Norm excella's Avatar
1971 31' Excella 500
Many , Louisiana
Electrical issue
Our 71 excella is parked for the remainder of the summer plugged in with only the refrigerator running but as I walked in the other night to look for a few items that we were missing from inside, it seems as the electricity was flickering about every three or four seconds I could hear a popping sound. Any ideas or suggestions?
Norm excella is offline   Reply With Quote
Old 08-20-2015, 06:51 PM   #2
2007 22' International CCD
Unplug it NOW. Then figure out what is loose or arching before it catches fire....
Old 08-22-2015, 10:30 PM   #3
Many , Louisiana
Son "borrowed" my battery for trolling motor on boat and Positive cable off battery touching frame and shorting system. Geez!
Old 08-22-2015, 10:56 PM   #4
Hopefully it did not fry the converter. I assume you have insulated the cable from ground and everything should have recovered. If you are plugged in you can do without a battery.
I would be in a rather intense discussion about electrical safety and borrowing stuff without letting me know in advance....😄
Old 08-23-2015, 02:53 AM   #5
Many , Louisiana
Yes all is well thanks for the advice.
Old 09-04-2015, 08:55 PM   #6
1978 Argosy 27
Madison , Mississippi
This is my first post ,and my first Airstream Argosy. I'm sure to ask a stupid question but please go easy on me.
I recently purchased a 1978 Argosy 28. While going through and checking all of the systems I plugged the refrigerator in and it shorted out due to a loose wire. As a result, I lost power. No breakers were tripped, but I did find that a 20 fuse was blown. I replaced the fuse, and regained power to everything except for my 12v lights.
My initial question is, if my converter is bad should I still have lights?
Thanks for any help you may offer.
je
emmojo is offline   Reply With Quote
Old 09-04-2015, 09:17 PM   #7
1978 Argosy 27
Sorry for hijacking your thread.
je
Furnace issue turns out to be AS issue 92landyacht Land Yacht/Legacy Motorhomes 16 01-20-2016 11:19 PM
Electrical issue? jornvango General Repair Forum 7 11-25-2012 08:55 AM
Electrical issue vicn2000 Electrical - Systems, Generators, Batteries & Solar 3 04-23-2012 07:14 AM
Help - electrical issue! mastercaster Batteries, Univolts, Converters & Inverters 21 04-09-2012 02:56 AM
2006 Safari Electrical issue Viper Batteries, Univolts, Converters & Inverters 7 08-17-2010 09:04 AM
