Hey,
Just got a 31 foot 1971 Sovereign and it's in great shape. Only thing is, it seems my battery charger makes a loud buzzing noise, that fills the whole cabin. It is the original charger, and I think it may be kaputt.
Any suggestions on how to trouble shoot this? I have an awesome electrician on hand to install/work on it. Do I need a newer and more up to date charger?
Thanks for all help, I am very new to the Airstream world, but very excited.
It is most likely a Univolt and they are notorious for overcharging batteries and boiling out the water.
You need to replace it with a converter with a 3 stage charger. When you swap it out save the fuse panel from the Univolt as you will need it with the new converter.
I have (I think) a Progressive Dynamics 9260 a 65 amp with built in battery minder they call a Wizard.
There are many good 3 stage converters on the market.
As garry stated, it is probably the Univolt (assuming your's is original). They are notorious for buzzing, or loud humming. Ours has buzzed for several years in the key of G.
Most of us upgrade to more modern electronics, as the old stuff is known to boil batteries.
Welcome to the group by the way.
Regards,
Kevin
__________________ Experience isn't always the best way to learn...You usually get the lesson first...And the instruction afterwards...
I replaced my old univolt 'cause the buzzing was so loud I couldn't sleep. The folks at Best Converter were a big help. It's an easy change out and they can help you get the right size for your unit.
Welcome to the Forums.........
The buzz can be cured by taking the Univolt apart and repotting the transformer coils in varnish. But if you are going to go through that, better to replace it with a new 3 stage converter. Or use it for a nice drone for chanting the Airstream mantra Aaah Looo Meeee Nuuummm.
Mine in the Overlander Humm's also. That's because it don't know the words. ALUM MA NUM. You will get use to it. If it aint broke dont fixit. Check the batteries at least once or twice a month it only takes 5 minutes to pop the caps and add distilled water. I have added only once in a year.
By checking you can tell if its boiling the water and if its boiling the water out it may be time for a change.
Roger & MaryLou
___________________
F350 CREWCAB SW LONG BED
7.3 liter Power Stroke Diesel
1977 27ft OVERLANDER KA8LMQ AIR # 22336 TAC- OH-7
My your roads be straight and smooth and may you always have a tailwind!
We have a new Xantrex converter in our '74 A/S as well as a new 12 volt AM, FM, CD radio. When the converter goes into charge mode the radio emits an annoying electronic sound that over rides the AM frequency. When the converter shuts down the AM signal returns.
The PO replaced the AM antenna with a flexible rubber antenna about 16" in height.
How should one trouble shoot this problem?
Does the tip of the antenna need to clear the top of the A/S?
The AM signal in question is strong / 45 miles distant.
Hey,
So I just put a Progressive Dynamics Inteli-Power 60 Amp RV Converter/Charger #9260. I worked ok for awhile but not I have lost all my 12v power. Overhead lights, anything like that won't work.
The Univolt is still in there and I checked the fuses, at least the small ones.
When I bought my 1974 Ambassador, I could only run either AC or DC. But some judicious wiggling of the wires connecting the Univolt to the world fixed that problem.
Well, it was a cheap fix, anyway. (No, my unit doesn't travel.)
Reason: Fix quote
