Old 07-21-2011, 05:07 PM   #1
2004 19' Bambi
Santa Barbara , California
Electrical - Adding a 110V outlet from Battery
Hi,
We own an '04 Bambi that has an 80w Go-Power Solar system installed. The solar keeps the batteries charged and we never have to worry about low batteries. We do a lot of dry camping however, none of the outlets work off of the battery. Is there a way to adapt an outlet or add a new outlet that can work off of the battery? Perhaps use a 12v inverter?
Your help / ideas would be greatly appreciated.
Ric
sbair is offline   Reply With Quote
Old 07-21-2011, 07:03 PM   #2
richinny's Avatar
2011 34' Classic
what are you looking to run off that outlet?
Ricky
Old 07-21-2011, 07:14 PM   #3
AirsDream's Avatar
1999 23' Safari
Perrysburg , Ann Arbor
Sure, you can run an inverter to power 120v items.
BUT - remember that they are gonna' draw a lot more amperage at 12v than 120v - more than 10x, given inverter inefficiencies. So a small 240 watt appliance that only draws 2 amps at 120v will draw something on the order of 25 amps at 12v ... your battery won't last long at that rate of discharge. Plus, even at this rate of draw, you need pretty hefty wiring to prevent overheating of the battery connection wires.
I've got a 260 watt solar system and three Lifeline batteries: I also have two SMALL inverters for running very small items such as an extra fan for cooling, or a cell phone charger, etc. Everything in my trailer runs off of 12v except for the microwave and the a/c.
AirsDream is offline   Reply With Quote
electrical, solar, 120 volt
Adding Interior 110 outlet from Solar sbair Modifications 7 03-17-2013 08:21 PM
Adding a second battery Kimball Electrical - Systems, Generators, Batteries & Solar 1 05-15-2011 12:27 PM
1960 Electrical 110V & 12V question Lothlorian Electrical - Systems, Generators, Batteries & Solar 19 05-08-2011 11:58 PM
'62 Safari electrical update questions Peggy Wilson Electrical - Systems, Generators, Batteries & Solar 3 02-12-2011 07:23 PM
