Old 06-23-2019, 11:17 AM   #1
Lafitte's Avatar
2019 25' Flying Cloud
Bullard , Texas
electric questions
Hi ,
Newbie to forums ( not new RV'er). With our new 25 FC, I have a 50 amp Autoformer and a 50 amp Surge Guard 44270 Entry Level Portable Surge Protector - 50 Amp.
? Which one do I plug into the campground pedestal first ?
Second question--? When at storage shed I use a Battery Tender . Do I hook +to first battery + battery terminal and - to second Battery - terminal ?
Lafitte
I always keep a supply of stimulant handy in case I see a snake ......which I also keep handy
Lafitte is offline   Reply With Quote
Old 06-23-2019, 11:35 AM   #2
2019 30' Classic
Charlotte , North Carolina
Autoformer first. Surge protector may detect a low voltage situation and shut off current. If the autoformer is after the surge protector, it won’t have a chance to step things up.
I only use the autoformer when volts look low. Crowded, old campgrounds mostly. Otherwise I leave that heave thing in the ‘trunk’. But I use it maybe 1/3 to 1/2 the time.
LilPeanut is offline   Reply With Quote
Old 06-23-2019, 11:40 AM   #3
ZOZ
ZOZ's Avatar
2018 23' Flying Cloud
Peru , Illinois
Tender
Originally Posted by Lafitte View Post
... When at storage shed I use a Battery Tender. Do I hook +to first battery + battery terminal and - to second Battery - terminal ?...
Yes.
zoz
Cindy & Randy
2018 AS Flying Cloud 23FB
2018 GMC Sierra Denali 4x4 6.2L
ZOZ is offline   Reply With Quote
Water Heater runs on Gas/Electric with electric switch on CoastieJohn Water Heaters, Filters & Pumps 3 04-02-2019 07:56 PM
Atwood LP/Electric Water Heater Problems (Electric Has Failed) gquake Water Heaters, Filters & Pumps 10 06-29-2014 04:02 PM
For electric for genration hase to be oun for electric RichardT Electrical - Systems, Generators, Batteries & Solar 7 12-05-2005 09:05 PM
Questions, Questions, Questions LowellN Repairing/Replacing Floor &/or Frame 5 10-28-2004 08:23 PM
Electric or Gas electric fridge replacement?? tin can luv Refrigerators 26 03-22-2004 10:50 AM
