Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar > Batteries, Univolts, Converters & Inverters
Old 11-13-2007, 08:57 AM   #1
craftsman's Avatar
Profile:  2007 25' Classic
Hydes , Maryland
Airstream Installed Inverter
The cost of the Airstream Inverter option is around $900.00. I know it's a true sine wave inverter but that still sounds expensive compared to other models that I've found doing a Google search. Does anyone know what brand Airstream installs and if this is not only an adequate size at 600watts but a good price installed by the factory?
Craftsman
craftsman is offline   Reply With Quote
Old 11-13-2007, 09:33 AM   #2
More than one rivet loose
thecatsandi's Avatar
Profile:  2006 31' Classic
Missoula maybe Helena soon , Montana
It is not just the inverter. At least in my case the 120V wiring has to be run in the opposite direction than the regular wiring.
My inverter runs my TV, Sattelite DVR and DVD Player full time. THe only thing they should have done was install an outlet in the bedroom so I can watch TV in bed while "boon docking"
Michelle
If you think you are having a bad day go to the hospital and visit the children.
Sarah
Ruby, (05 BMW R1200RT)
Daisy, (06 Turbo Diesel F-250 w/Tow Command, the perfect TV)
Butter Cup, (06 Classic 31 w/dinette, solar)
45,000 miles in two years!
http://Michelles-Adventures.US
Old 11-13-2007, 09:38 AM   #3
at Cabela's South Dakota
wheel interested's Avatar
Profile:  2007 27' Classic FB
Lapeer , Michigan
Images: 117
There was a post of Silvergate's inverter and picture. Will that help? He lists the brand also.
SilverGate's Safari is Home at Last!
-Carol
Adopt the pace of nature: her secret is patience. ~Ralph Waldo Emerson
wheel interested is offline   Reply With Quote
Old 11-13-2007, 10:06 AM   #4
craftsman's Avatar
Hydes , Maryland
Hey, thanks. I found them. They sure make a lot of different products, from lights to landing gear.
Craftsman
Old 11-16-2007, 10:15 AM   #5
Commercial Vendor
Profile:  Boise , Idaho
Images: 21
Airstream uses the WFCO pure sine inverter and it is a good one. $900 means they are charging $600 to install it. I don't know how many hours they figure, but I do it in less than one. We carry it for under $300.
Old 11-16-2007, 08:11 PM   #6
Motoman's Avatar
Profile:  2005 25' International CCD
1960 18' "Footer"
Riverside , California
Randy does have great prices on the WFCO inverter and quick delivery but Randy, some of the floor plans require quite a bit of work and feeding possibly one or two romex circuits back through a small raceway to intercept and supply 120v to the flat screen TV's and supply the refrigerator and other outlets from a circuit that doesn't come through the inverter. It can be done but I spent a couple of hours planning ours and the connection to the battery since everything gets mounted up under the front sofa/gaucho in our 25'CCD.
Don (KD6UVT) & Gail Williams
What do you want to be in life, a spectator or a participant?
SNU #157
FCU #004
Motoman is offline   Reply With Quote
Old 11-17-2007, 12:23 AM   #7
Commercial Vendor
Images: 21
I understand. If there is a way to document and take photos, please do.
Pingbacks are On
New to Airstream - inverter problems already Badco8 Member Introductions 6 03-24-2007 01:57 PM
Should our TV have an Isolator Installed? wheel interested Towing, Tow Vehicles & Hitches 6 11-28-2006 10:18 AM
Installed the A/C... Anon Furnaces, Heaters, Fireplaces & Air Conditioning 40 06-13-2005 07:46 AM
Generator installed in Airstream flyfisher Generators & Solar Power 14 01-22-2004 06:48 PM
SEO by vBSEO 3.1.0
