Old 11-14-2010, 06:15 PM   #1
shepherd57's Avatar
1985 32.5' Airstream 325
Lindsay , Ontario
Elec troubles
I was changing the light bulbs in the control center when the power wire from the stove fan touched the the panel. Now I don't have any interior lights and no power at the control panel when on shore power and the engine won't turn over. If I turn to accessories I have interior lights. I also have 110 when on shore power.
I can't seem to find a blown fuse and the inverter is still humming and I have 12 volt power at the fuse block after the inverter.
How can a tiny spark kill everything that was working fine before.
shepherd57 is offline   Reply With Quote
Old 11-14-2010, 06:25 PM   #2
Gypsy Jo's Avatar
1977 28' Argosy 28
Bullhead City , Arizona
On my control panel I have a fuse in the side.Do you have one there?
Gypsy Jo
1977 Argosy 28' Motor Home
Gypsy Jo is offline   Reply With Quote
Old 11-14-2010, 06:45 PM   #3
shepherd57's Avatar
Lindsay , Ontario
the only one is a 15 amp inline and it is good I have no power coming to the control panel
Old 11-14-2010, 06:53 PM   #4
Gypsy Jo's Avatar
1977 28' Argosy 28
The schematic I have shows 2 wires from the control panel. One goes to the vehicle junction box and the other one to the solenoid on the 12 volt distribution panel . You might have messed up that solenoid because it is hooked to the engine battery.Not an expert just giving ideas.
Gypsy Jo
Old 11-14-2010, 06:59 PM   #5
shepherd57's Avatar
Lindsay , Ontario
Is there a color code for those wires and where do I look for that solenoid
Old 11-14-2010, 07:15 PM   #6
Gypsy Jo's Avatar
1977 28' Argosy 28
The distribution panel on my 28' is under the passenger side chair .It has a drop down door that was under the carpet the solenoid is there.Doesn't show a color code in the book.
Gypsy Jo
Old 11-14-2010, 07:54 PM   #7
shepherd57's Avatar
Lindsay , Ontario
Is that a square plastic piece with 2 sets of points inside it
Old 11-14-2010, 08:12 PM   #8
Gypsy Jo's Avatar
1977 28' Argosy 28
No the solenoid is round with 2 large posts and 2 small posts.I don't have any way to show you the schematic or a pic right now.If you search the forums there is info on where to find an owners manual.That would give you a better idea of what you are looking at.
Gypsy Jo
Old 11-15-2010, 10:31 AM   #9
shepherd57's Avatar
Lindsay , Ontario
I don't have a solenoid that I can find. I now have the engine running I had the neutral switch disconnected. I have 12 volt power with the key on acc and in the run position.
I don't have 12 volt when when connected to shore power.
I have a Magnetek 950-2-4 converter 50amp
Dose anyone know if there are any fuse-able links in these systems that could be the problem.
Can I test the converter to see if it is putting out 12 volts
Elec troubles shepherd57 Argosy Motorhomes 5 11-15-2010 05:44 PM
awning troubles poncho/cisco Awnings 3 11-09-2008 09:41 AM
Still having water troubles.... swinginping Classic Motorhomes 1 03-07-2008 05:46 PM
Awning Troubles Alaska1966 Awnings 1 08-01-2007 11:51 AM
Water troubles... Sneakinup Fresh Water Systems 5 01-10-2004 09:54 PM
