Old 03-24-2011, 07:45 AM   #1
robwok's Avatar
1964 26' Overlander
Richmond , Virginia
Images: 35
Dual system? Am I going to blow it up?
I promise, I tried to find this answer.
I have a 64 overlander. In mine, I had a smaller univolt, and a switch system that you flipped when you were running off of battery or shore. I'm pretty sure it's original since it has the original zolatone spray all over it. 64 was a year of experiments, and mine was an international version.
So, my concern is that I've heard that the lights were both DC and AC. Sure enough, last night I hooked up the DC only portion of my system to the intelli-power all in one unit. All the lights came on. My big concern though is that if I hook up the AC lines, I may short something out since there is no longer a switching system. I plan on hooking the two systems seperately, until I find out which wires run the AC to the lights and fans. Then, I plan just to capp off those AC lines and run everything that can be run off of DC just on DC, saving the AC lines for the fridge, outlets, new water heater, and eventually an AC.
Any opinions here? Any reason I shouldn't try running everything off of DC? I'd need it that way when I unhooked anyway.
robwok is offline   Reply With Quote
dual voltage, 120 volt, intelli-power
Rock Tamers Mud Flap System au_ee Tow Vehicles 42 10-28-2016 06:50 AM
System of a grill Jammer Stella's Kitchen 30 02-27-2011 10:15 AM
Leveling system on my 1992 Legacy Desikk Land Yacht/Legacy Motorhomes 0 02-08-2011 01:50 PM
Hydraulic leveling system. boatdoc Jacks, Stabilizers, Lifting and Leveling 18 02-08-2011 05:30 AM
