Old 11-23-2009, 11:54 AM   #1
1983 34' Limited
Las Vegas , Nevada
Send a message via MSN to dmadam
Dual Batteries
on an '83 34' limited is the dual battery wires in there wired as series or parallel? I am putting in dual 6 volt batteries and not sure if the preinstalled leads are for dual 12 volt or dual 6 volt.
David
Retirement happens when you get over the illusion of usefullness.
dmadam is offline   Reply With Quote
Old 11-23-2009, 12:22 PM   #2
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
The original ones in my '83 34' Excella are parallel wiring to 12 volt batteries. If you have 12 volt batteries now, they will be parallel.
Two 12 volt batteries in series would yield 24 volts, just as two 6 volt batteries in series would yield 12 volts.
Vaughan
Old 11-23-2009, 02:25 PM   #3
1983 34' Limited
Las Vegas , Nevada
Thanks, I had one 12 and switching to 2 sixes and did not know if it was set up for two 2 12's in parallel or two 6's in series.
Thanks much
Old 11-23-2009, 02:32 PM   #4
1983 34' Excella
1967 24' Tradewind
Images: 32
You're welcome! If you load the first photo here: http://www.airforums.com/forums/f449...0-a-57567.html and zoom in on the fuse panel, you can see the leads coming in from the top from the batteries. The two large black cables on the far right are both negative battery leads and the two large red ones next to them are the positive battery leads. The actual parallel connection is made at the fuse block itself.
Vaughan
Dual Batteries seeflash Batteries, Univolts, Converters & Inverters 4 05-17-2009 09:47 PM
Upgrading my CCD to dual batteries silverback Electrical - Systems, Generators, Batteries & Solar 7 05-20-2008 07:58 AM
Dual Batteries trning 2003 Safari 0 03-29-2004 11:01 PM
Dual Gray Water & Dual Black Water? nvestysly Waste Systems, Tanks & Totes 5 05-09-2003 05:40 AM
Univolt/Dual Batteries uwe Batteries, Univolts, Converters & Inverters 4 06-28-2002 08:26 PM
