Old 11-13-2004, 09:03 PM   #1
a.k.a. Ambassador Tim
Safari Tim's Avatar
1960 28' Ambassador
Northern , California
Images: 35
Don't forget: Check your battery water level....
Just a reminder to you to check your battery water level. Even if you have a triple stage charger
I was removing my front gaucho, subject for another topic, and my charger cycled and the lights went totally out for a second and the radio turned off. When the charger came back on, lights again
I thought uh oh I unpluged the trailer and pulled the battery. It was dry as a bone. It took nearly a gallon of distilled water to get fluid above the plates.
I plugged it back in and appears to be keeping a charge
Hopefully no permanent damage. I have a statpower tri-state charger, but I never checked the battery water level having owned the trailer 3.5 years now.....
So, make it part of your chores!
-Tim
theVAP - Airstream Podcast
Old 11-14-2004, 08:48 AM   #2
Kistler's Avatar
2002 25' Classic
Oro Valley , Arizona
Sorry about this hijacking but it is sorta related......if/when I remove my batteries for the winter and bring them home to my garage,
should I put them on anything (like cardboard) other than the cement floor?
should I put them on a charger? should I just leave them on a charger?
if, to be left on the charger, how do you connect two batteries to one charger?
Having given away my 3 amp charger, can I use my 15 amp charger? Maybe I could alternate batteries on it like once a week?
Kistler
Kistler is offline   Reply With Quote
Old 11-14-2004, 12:30 PM   #3
silverback's Avatar
2006 28' Safari SE
Sierra Vista , United States
At least once a month...
With our solar panels keeping the batteries nicely charged in the Arizona sun, I check at least once a month and top off if necessary. So far I've seen very little decrease in the electrolyte in the cells.
Ken
4CU Charter Member
silverback is offline   Reply With Quote
Battery check--why don't I ever have to add battery water? Kistler Batteries, Univolts, Converters & Inverters 8 05-17-2004 09:03 PM
Univolt reminder ** Battery Check! Sav'h Steve Batteries, Univolts, Converters & Inverters 21 10-07-2003 02:18 PM
Checking water in the battery... drboyd Electrical - Systems, Generators, Batteries & Solar 1 08-15-2003 09:37 PM
water system mystery garymacf Plumbing - Systems & Fixtures 4 06-21-2003 11:50 AM
Battery Level Display uwe Electrical - Systems, Generators, Batteries & Solar 4 07-04-2002 07:31 PM
