Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar > Batteries, Univolts, Converters & Inverters
Old 10-11-2008, 08:58 PM   #1
azfiredog300
azfiredog300's Avatar
Profile:  1971 25' Tradewind
Surprise , Arizona
Does it work
How do I test if my univolt is working at all or working properly?
Jerry C.
"Travelstar Galactica"
WBCCI #13317
Member of the Four Corners Unit
The only true failure is the failure to try.
azfiredog300 is offline   Reply With Quote
Old 10-11-2008, 09:05 PM   #2
Janet's Husband
Janet's Husband's Avatar
Profile:  1977 Argosy Minuet 6.0 Metre
1977 Argosy 24 Rear Door
Eastern , Washington
If you have a volt meter check the output should be better than 13.4 VDC
Then check the AC ripple should be less than 300mV AC. If not you caps are dried out and they should be replaced. Better yet replace the "Old Battery Boiler" with a new multi-stage charger.
Second way, unhook the battery and see if the lights work and are bright.
Peace
Gary
Janet's Husband is offline   Reply With Quote
Old 10-11-2008, 09:16 PM   #3
azfiredog300
Surprise , Arizona
What multistage charger would you suggest? Do you mean unhook the battery when I am hooked up to tow vehicle or land line?
Jerry C.
WBCCI #13317
Old 10-11-2008, 09:21 PM   #4
Janet's Husband
Unhook when you are on shore power. I personally like the inteli-power 9100 or the 9200 45 amps or bigger. Faster charge time. Take a look at RV Power Converter/Chargers and see what you think.
Peace
Gary
Old 10-11-2008, 09:22 PM   #5
overlander63
Rivet Masher
overlander63's Avatar
Profile:  L.A., Dammit , California
No, the quick and dirty Univolt function test is to disconnect the battery, plug in the trailer, and see if the lights come on. If they do, it does.
I would second Gary's suggestion for a new converter. I like the Intellipower we have, I got it from Randy (68overlander) at Best converters (BestConverter - Converters, Inverters, Electrical Supplies, Electronics)
Old 10-11-2008, 09:27 PM   #6
azfiredog300
Surprise , Arizona
Thanks very much for the input,I will look into it right away. I can't wait to get it out of the storage yard and get working again, been a couple months and I am going through withdrawal.
Jerry C.
WBCCI #13317
What Do You Do For Work? flamingo-kid1 Community Polls 537 11-06-2008 06:45 AM
Would this work? Chuck Waste Systems, Tanks & Totes 17 04-16-2008 06:43 PM
Would It Work rebel beck Our Community 5 08-09-2006 10:51 PM
they work....... another project Electrical - Systems, Generators, Batteries & Solar 3 11-30-2003 05:46 PM
How does this work??? thenewkid64 General Motorhome Topics 7 07-21-2003 09:58 PM
