Old 05-08-2010, 12:14 PM   #1
nick6930's Avatar
1979 Argosy 27
1969 21' Globetrotter
1953 25' Cruiser
Front Royal , Virginia
DOC Wattson Battery Meter HELP!
I am the first one to admit that electrical is not my field. We have been boon docking a lot and want to see how the battery life is doing. I wanted just a simple meter that acted like a gas gauge green good red bad. However, I saw this DOC Wattson model R102 digital panel meter. It sounds like it does the gas gauge thing and a whole lot more. MORE GOOD well maybe not.
First I am not sure how to hook it up. The diagram shows one end from battery the other end to charger. The only place for me to hook it up easily is in the 12v fuse panel. Does this look right??
The other issue is that not all of the readings offer information they are just at 0 the only thing the shows a reading is the volts. It show volts being used and the charging volt.
Maybe the way I have the battery connection (load side) and the other connection on the same side of the fuse panel it is not drawing 2 different readings. Would it be better to hook directly to the converter??
Any and all recommendation are appreciated. This thing may just end up on ebay before the weekend is over.
Name:	DOC Wattson model R102 digital panel meter.jpg
ID:	102036   Click image for larger version
nick6930 is offline   Reply With Quote
Old 05-08-2010, 01:21 PM   #2
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
Your unit is a combo amp / volt meter. It also converts amps to watts, but that is simple math. In order to see amps or watts, there needs to be current flowing through the meter. It looks like you attached the meter to the lugs where converter attaches. There would be no current flowing through the meter and you would see zero amps and zero watts. You will only see voltage.
Richard
Old 05-08-2010, 01:25 PM   #3
jm2
jm2's Avatar
2002 25' Safari
1977 20' Argosy 20
northern valley , new jersey
Nick,
though I can't say that I've ever used one of these devices,
this looks like the Swiss Army Knife of power meters! here's a link from someone who's apparently been down your road before - Watts Up and Doc Wattson power meters.
when all else fails I try reading the manual.
let us know how it works out for you?
best,
Joseph & Gabrielle
Simplicity is the ultimate sophistication - Leonardo da Vinci.
WBCCI 2087 - AIR 3144 - TAC-NJ2
http://defendwally.org/
jm2 is offline   Reply With Quote
Old 05-08-2010, 04:19 PM   #4
nick6930's Avatar
1979 Argosy 27
1953 25' Cruiser
Thank for your help. The link was a big help for me understand it a little better. It still does not work the way I want it too. But after a bunch of sparks, cursing and the handy dandy multimeter I was able to figure out a 12v problem that just started this year where the 12 volt would sometimes work and sometimes not work. A 30 year old fuse that looked fine with the multimeter I discovered it was not. AND the neg fuse from the battery was lose.
My intent was to hook the Doc Wattson up so I could see the draw of everything on the 12v and the condition of the battery. however, I dont really see how to do it. I read the manual and played around with it and I can not figure out how to hook it up to the fuse box to work that way. I may just go buy a simple volt meter that I can see how much juice the battery has. Maybe there is something in the forums that will describe how to that.
Thanks again for your help. I will think about it a little more but I think it will be ebay bound.
Old 05-08-2010, 04:37 PM   #5
2011 25' FB Flying Cloud
Anywhere & , Everywhere
Is this what you were looking for?
Link 20
Al - K4GLU is offline   Reply With Quote
Old 05-27-2010, 07:07 PM   #6
Central , Mississippi
Filler' up!
It MAY not give ya what ya want...
I did some lookin' at those and unless I missed something, that's a 1 way meter...it will totalize all the juice you pull from the battery...BUT...it doesnt take into account what juice the charger puts back INTO the battery...
What that means is kinda like measuring how much gas your engine is burning but having no idea how much is being been added to the fuel tank...
The only solution I have found for a meter that will tell ya' how full is your battery (based on usage and recharge) is the bigger $$$$ units like the LINK or Trimetric's...
My Trimetric arrived today from Randy (Best Converter) so I'll be doing an install this weekend.
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 06-03-2010, 10:44 PM   #7
Soyboy's Avatar
1999 28' Excella
Frederick , Maryland
Images: 44
HiHo, where in the trailer did you install the meter?
1999 28' Safari
2012 F150 Platinum Max Tow 7650 GVWR 3.73 Elec. Locking Diff.(Prev 2003 Dmax).
Honda EU2000i, Equalizer Hitch
AM Solar Panels 150W - 2 Trojan T 105 6V Batteries
TAC MD-6
AIR 4534
On internet forums, please research and separate the wheat from the chaff (including mine!)
Soyboy is offline   Reply With Quote
Old 06-05-2010, 07:34 AM   #8
Street Side, just fwd of the dinette. I have a 110V outlet with a Kill-o-Watt meter I use to monitor the Campground voltage so I mounted the Trimetric right next to it. The wiring sneaks down and behind the cabinet, forward under the wall mounted table, down an interior panel seam to the shunt thats mounted on the internal wall skin between the two battery boxes.
Old 06-05-2010, 08:19 AM   #9
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
Hi Nick,
If you like to boondock you've got to get a good multimeter for your batteries. I would recommend a Link 10 which provides voltage, amps being used, a history of amps used since last charge, and how long you have on your present charge until you need to recharge your batteries.
I have the Link 1000 which does the same thing as a Link 10 but it also controls my Freedom 10 Inverter/Charger. A great setup which provides
110v AC to all of my outlets. My Sovereign is a boondocking machine.
You can see pics of my installation on my blog.
Good luck!
1958 Overlander
2011 Wolf Creek 850N TC
2011 Ford F-250 Crewcab (6.2L), 3.73RE
WBCCI #5661/AIR #5661/TAC # AZ-6
4CU 1st VP
My '58 Overlander Restoration and Travel Blog:
http://mellomikesairstreams.blogspot.com/
mello mike is offline   Reply With Quote
Old 06-09-2010, 10:42 AM   #10
nick6930's Avatar
1979 Argosy 27
1953 25' Cruiser
Thanks for all the suggestions. I truly only wanted a gas gauge for the battery to tell me if it was full or empty. Then I thought about going a little more high tech for a few extra bucks. But that idea did not work. So I just went and bought a honda generator last week so that I don't even have to worry about it anymore. Not sure how I got from a $50 gauge to a $900 generator but either way the batteries will have juice.
Thanks again.
Old 06-09-2010, 11:09 AM   #11
Originally Posted by nick6930 View Post
...Not sure how I got from a $50 gauge to a $900 generator but either way the batteries will have juice.
Thanks again.
We have a technical term at work for that phenomenon, it's called 'scope creep'
Old 06-09-2010, 11:45 AM   #12
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
Yep!!
1958 Overlander
4CU 1st VP
Old 06-09-2010, 11:56 AM   #13
DEITZ645's Avatar
2006 30' Classic S/O
Mohrsville , Pennsylvania
Severe Scope Creep
I have severe "scope creep" then. I started out looking at battery monitoring systems, then the little Hondas, and ended up with a Yamaha EF3000iSEB so we can run the AC, hair dryer (for the Mrs.), or the convection oven (no gas oven in the '06). I do have to say it has come in handy for power outtages at home and boondocking.
Carl, Elaine & Finn The Beagle
2006 30' Classic W Slide & Limited Package Katarina
2006 GMC 2500 HD 6.6 Turbo Diesel Crew Cab 8' Bed
TAC PA-3
S/OS#042
AIR #14487
NQ3U (was KB3UOM)
DEITZ645 is offline   Reply With Quote
battery meter, doc wattson
78 Sovereign: batter recharger\transformer puzzle page.crow Batteries, Univolts, Converters & Inverters 0 04-09-2009 08:57 AM
Get a Fluke meter? markdoane Batteries, Univolts, Converters & Inverters 26 05-22-2008 02:08 PM
Value of a 6 meter Argosy? Ultradog All Argosy Trailers 9 06-27-2006 09:24 AM
Propane meter Devoman LP Gas, Piping, Tanks & Regulators 6 11-24-2005 06:53 AM
Rot Doc, and what kind of wood? 58BUBBLE Repairing/Replacing Floor &/or Frame 13 04-19-2005 09:08 PM
