Old 07-20-2009, 06:42 AM   #1
kevinkatz's Avatar
1965 17' Caravel
Curtis Wright
san marcos , Texas
Images: 38
Send a message via AIM to kevinkatz
do you have to have a battery?
do i have to have a battery in my 65 caravel if i am leaving it parked and will be running it on 110v? if i do need a battery in at all times, when i am not using the AS should i leave it plugged in and on, or can i unplug it?
i will only be using it for about one weekend a month.
obvioiusly on the road i need the battery.
kevin
kevinkatz is offline   Reply With Quote
Old 07-20-2009, 06:46 AM   #2
centennialman's Avatar
2016 20' Flying Cloud
Centennial , Colorado
Kevin,
If you are leaving it idle and only using it once a month, I would only plug it in then. Will you be wanting to leave anything running when you aren't there....like the refrigerator?
If you are not towing and it's just sitting, you don't need a battery and it might be best to have the battery at your home on a trickle charger to keep it charged up.
Steve "Centennial Man"
centennialman is offline   Reply With Quote
Old 07-20-2009, 06:52 AM   #3
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Are your using a Converter like a Univolt or newer to use 12v lights, etc? The jury is out on if you should actually have a battery in or can just run off the converter.
You could put in a used car battery for next to nothing.
A battery will discharge by itself over time. A month will show some drop, but you should be able to unplug with no problem. You can put in a demand type trickle charger to keep the battery topped off. If you have a Univolt I would not leave it plugged in for a month when you are absent as that can harm the battery.
Old 07-20-2009, 07:25 AM   #4
kevinkatz's Avatar
1965 17' Caravel
Curtis Wright
san marcos , Texas
Images: 38
i dont know if i have a converter. new to this. there is a transformer thing in the As that has two switches on it that say "12v" or "city power".
what is what called?
Old 07-20-2009, 07:33 AM   #5
All 1965 Airstream's had a Univolt, that was a battery charger and a source for 12 volt DC power, except the Caravels.
The Caravel model had a 12 volt and 19 volt AC transformer, as you describe.
You do not need a battery, since the only way the battery could be charged, was when the trailer was hooked up to a properly wired tow vehicle.
Make sure a previous owner did not have a 12 volt DC charger wired into the system.
You can easily update the trailer system, with a fuse panel and a Univolt, so that the 12 volt DC system works as it does in all the other 1965 and up trailers.
Old 07-20-2009, 07:39 AM   #6
WILDRTEXAS's Avatar
1970 27' Overlander
ARLINGTON , TEXAS
Images: 31
Send a message via Skype™ to WILDRTEXAS
New too. Any battery info would be so helpful. Thank you all......
WILDRTEXAS is offline   Reply With Quote
Old 07-20-2009, 08:57 AM   #7
purman's Avatar
1968 28' Ambassador
Cedaredge , Colorado
If you have a newer fridge they need 12v to run the control board so you will need a battery in this case
Jason
2008 5.7 L V8 Sequoia
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Battery in a 58 ? 60's Iron Batteries, Univolts, Converters & Inverters 5 07-19-2006 07:31 AM
Which Battery Craftsman Batteries, Univolts, Converters & Inverters 4 07-30-2004 10:01 AM
Wiring Sequence to hook up 2 x 6 volt battery pack to your 12 volt trailer battery TobyJH Batteries, Univolts, Converters & Inverters 0 05-21-2004 12:04 AM
Battery check--why don't I ever have to add battery water? Kistler Batteries, Univolts, Converters & Inverters 8 05-17-2004 09:03 PM
When A/S on AC, do you let the battery on ? brunoffrance Electrical - Systems, Generators, Batteries & Solar 8 11-02-2003 03:28 AM
