Old 07-27-2009, 10:42 AM   #1
1965 24' Tradewind
fort worth , Texas
do i need a battery to run tail lights?
i was just wondering if i needed to have a battery hooked up on my 65 tradewind for the tail lights or running lights to work. i know on small trailers i have you don't, i did'nt know if an old airstream was an exception.
jesse young is offline   Reply With Quote
Old 07-27-2009, 10:46 AM   #2
Dwight's Avatar
1999 34' Excella
Joshua , Texas
As long as the trailer is hooked to the tow vehicle, then the lights will work. The batteries in the trailer also serve to power the break-away system in case the trailer and tow vehiclel become separated, then the trailer brakes will be applied.
History doesn't repeat itself, people do!
Dwight is offline   Reply With Quote
Old 07-27-2009, 10:52 AM   #3
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
The lights will work without the battery, but you should have a working battery hooked up on the trailer or the emergency tailer brakes will not work is the trailer get separated from the tow vehicle.
Brian
SuEllyn & Brian McCabe
2015 FC 25' FB (Lucy) with ProPride
2020 Silverado 2500 (Vivian)
2023 Rivian R1T (Opal)
Old 07-27-2009, 11:39 AM   #4
Alwhisman's Avatar
1978 Argosy Minuet 7.3 Metre
Dayton , Texas
Images: 94
Send a message via Yahoo to Alwhisman
What is your TV, and have you hooked back up to another trailer to make sure they work. I have an F150, which has a separate fuse for clearance/tail lights to my receiver connection. I had it blow once and it really threw me for a loop, didn't make sense that they worked on my truck, but not the trailer.
Alwhisman is offline   Reply With Quote
Will fridge run without battery power? crazylev Refrigerators 16 07-29-2020 06:35 PM
No running lights or tail lights... goswick Lights - Interior & Exterior 24 02-27-2010 09:31 AM
Tail lights, brake lights, turn signals on '75 22' mendosoft All Argosy Trailers 3 06-01-2008 08:46 PM
'69 Tail lights. 69AmbassFl Lights - Interior & Exterior 12 03-26-2008 06:04 PM
Tail lights Chuck Electrical - Systems, Generators, Batteries & Solar 0 07-08-2002 01:58 PM
