Old 07-24-2010, 11:17 PM   #1
Calgary , Alberta
Do Airstreams Come Stock with Inverters?
OK,...2007 25' Safari SE,..we read through the manual and it sounded as though the TV and one other 120v appliance would work when not connected to shore power. Went out to the unit and nope,...no TV,..no other 120v anywhere,...they only work if im plugged in to shore. Does Airstream come stock with inverters or is this an option? We have the queen up front with the converter under the bed,...does the inverter usually live here too??
Thanks for tolerating the rookie!
M
Mihoff is offline   Reply With Quote
Old 07-25-2010, 12:01 AM   #2
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
M
First - we're glad to have you here. We were all newbies once.
If the television installed is original equipment, it could be a 12 volt. Look at the plug or read the info on the back to check. Many of us replaced the older televisions with HD wide screens - and it's much cheaper to get those in 120 volt versions. The lights should be 12 volt in a new unit. In some of the very old ones, there's a gas light that runs on propane. Your 2007 should have the original refrigerator which will also run on propane.
12 volt appliances like televisions will run your batteries down fast if you're boondocking. An inverter can be added, but would run your batteries into the dirt in no time.
Boondocking, you have options - a generator big enough to run EVERYTHING, one enough to provide everything but air conditioning, or a small one to recharge your batteries. We can cook, heat water and keep the unit warm with propane. You can add solar to an Airstream to recharge the batteries.
Most people re-think appliances once they become dedicated trailer people - a stove top percolater or a French press work just fine. Life without a microwave can be done. (Or that little Honda 1000 will let you cook with one.)
Paula
Old 07-25-2010, 07:17 AM   #3
richinny's Avatar
2011 34' Classic
i believe it was an option and would only work a few outlets. it would need to be switched on, as it always uses power.
Ricky
On adding batteries, inverters, etc., to tow vehicle Jammer Electrical - Systems, Generators, Batteries & Solar 15 01-13-2010 03:09 PM
Batteries, Chargers, Inverters and Wire Size amalgamator Batteries, Univolts, Converters & Inverters 0 03-24-2008 06:46 PM
Voltage Inverters mcostanzo Electrical - Systems, Generators, Batteries & Solar 12 08-01-2006 10:37 PM
Are these stock wheels? malconium Brakes & Brake Controllers 5 09-15-2004 07:32 PM
Inverters again ! Tinsel Loaf Electrical - Systems, Generators, Batteries & Solar 8 08-22-2004 07:22 AM
