Old 10-01-2008, 06:28 PM   #1
nd48463's Avatar
1977 31' Excella 500
Emmett , Michigan
Images: 72
Distribution panel upgrade
I am in the midst of a fuse panel upgrade. There was a leak (which I found and fixed) that totally ruined the fuse box behind the front gaucho. It rusted all of the terminals and loosened connections causing failure. I ordered a new 9 circuit fuse box and also replaced the auxiliary fuse holders for the tow lighting. The question I have is concerning the main negative cables from the battery. They are both fused and I cannot figure out why? In talking to an Electrical engineer at work he can't think of why wither and recommended me not fuse the negative main cables. Is there reason to? Any advice would be appreciated! The univolt is still in good condition so no plans to replace yet. The Distribution panel I bought is the 9 circuit from Parallax Power Supply. It is scheduled to arrive tomorrow.
Thanks.
Nate
Name:	Sept 08 031.jpg
nd48463 is offline   Reply With Quote
Old 10-03-2008, 04:22 PM   #2
New Borockton , Alabama
Images: 21
Nate,
I count at least 10 DC circuits in your panel. Parallax makes a 12 and 15 position fuse board as well just so you know.
Randy...Converters, Inverters, Trimetric, Surge Protectors, Zamp Solar, AGM Batteries
www.bestconverter.com
Old 10-03-2008, 09:01 PM   #3
nd48463's Avatar
Emmett , Michigan
Images: 72
Only 5 Circuits. The other 4 are the towing lights (Brakes, blinkers etc.) I have replaced and now have a good working electrical system!! I did not have room to keep the keep the ammeter connection, but I can live with that. I am just curios as to why Airstream fused the negative connections to the batteries??
Nate
Old 10-04-2008, 05:47 AM   #4
Images: 59
http://www.airforums.com/forums/f449...ive-38936.html
Old 05-21-2009, 03:57 PM   #5
1977 25' Tradewind
1992 29' Excella
Marietta , Georgia
Hey ND48463,
Your panel upgrade looks great.
What did you do with your 50 amp positive and negative fuses? From the pics it looks like you eliminated them.
Going thru the same upgrade and your pics have really helped.
Darren
Streamers is offline   Reply With Quote
Old 05-22-2009, 07:03 AM   #6
nd48463's Avatar
Emmett , Michigan
Images: 72
I bought some surface mound fuse pods that are typically used for stereo installation. I put them right inline off of the battery. I did the same for the positive lead going from the univolt. There is some pics of these on the forums somewhere, and you can buy them on ebay pretty cheap.
Hope this helps!
Nate
Old 05-23-2009, 01:14 PM   #7
1977 25' Tradewind
1992 29' Excella
Marietta , Georgia
Thanks Nate.
Darren
Broken Fuse Block In Distribution Panel - How Best To Repair montanaandy Batteries, Univolts, Converters & Inverters 12 06-01-2015 08:01 PM
Low voltage distribution panel...Help k9s2go Electrical - Systems, Generators, Batteries & Solar 4 12-29-2006 01:54 PM
Weight Distribution newae On The Road... 9 07-18-2003 10:08 PM
weight distribution Craig Hitches, Couplers & Balls 2 04-14-2003 06:57 PM
