Old 03-13-2010, 11:56 AM   #1
Goffstown , New Hampshire
Disconnecting the batteries
Any special order in which these should be disconnected??
Bobdes is offline   Reply With Quote
Old 03-13-2010, 12:00 PM   #2
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
Always remove the negative connection that goes to the trailer first. That will break the circuit if your wrench hits the frame when working on the other connections and prevent a short.
Remove negative first
Install positive first
Richard
Old 03-13-2010, 12:01 PM   #3
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
I always do neg first.. Slide the ends into short lengths of rubber hose and repeat.
"Any nation that can survive what we have lately in the way of government, is on the high road to permanent glory."
Molly Ivins
"Just because you don't know how, doesn't mean you can’t."
Amanamus
"Never tow faster than your Guardian Angel can Fly"
Sweet Streams....🌥
Old 03-13-2010, 12:05 PM   #4
Maniacal Engineer
barts's Avatar
Menlo Park , California
1) Disconnect AC power if connected.
You don't want to run the Univolt/converter/... w/o a
battery connected unless the unit is explicitly designed
to support that mode of operation.
2) Disconnect ground (black) going into the battery box.
Ground is disconnected first in case the battery box or
surrounding structure is grounded. This way, inadvertent
contact of the wrench & surrounding metal doesn't cause
problems (sparks, explosions, etc).
3) Disconnect hot (red) going into the battery box.
It's now safe to disconnect the hot lead, since the
surroundings are now electrically isolated from the
battery.
4) Disconnect cables linking the two batteries together in
either order.
- Bart
Bart Smaalders
Menlo Park, CA
http://tinpickle.blogspot.com
http://smaalders.net/barts
barts is offline   Reply With Quote
Old 03-13-2010, 08:20 PM   #5
Excellent info, makes sense. Thanks all.
Old 06-02-2011, 03:31 PM   #6
2008 19' International CCD
MONROEVILLE , Alabama
bart,
I have just posted a question about running the converter w/o batteries connected. I jsut found that you answered this below sometime back. Do you think it would be ok to connect an old and barely serviceable battery just to keep the converter from being damaged? I maintain my abtteries on a batteryminder and I want to have a/c power on the TT to run a dehumidifier/heater.
battery.
either order.
- Bart
AUTAILGATER is offline   Reply With Quote
Old 06-02-2011, 04:51 PM   #7
timmaah's Avatar
1999 25' Safari
On , the road
Originally Posted by AUTAILGATER View Post
bart,
Why not just flip the circuit breaker for the converter or unplug the converter? (Most have a normal 120v plug).
timmaah is offline   Reply With Quote
Batteries woodedareas Electrical - Systems, Generators, Batteries & Solar 5 04-30-2009 11:20 PM
Battery Disconnecting on Solar Application jeff4506 Generators & Solar Power 4 11-24-2008 08:32 AM
batteries jhenry Member Introductions 5 10-19-2008 03:03 PM
Batteries SJ Brown Batteries, Univolts, Converters & Inverters 9 06-17-2008 06:59 PM
Disconnecting toilet from tank vishwa Airstream Motorhome Forums 1 09-06-2003 03:25 PM
