Old 03-31-2008, 03:07 PM   #1
bertro's Avatar
1971 23' Safari
Groveport , Ohio
Disconnect question
Hello, I can find threads about shore power without a battery. I'm just wandering if when camping when connected to shore power with a full charge in the battery if I can turn off the 12V switch. Will this help with the lifespan of my lifeline battery.
bertro is offline   Reply With Quote
Old 03-31-2008, 03:25 PM   #2
2004 25' Classic
West Chazy , New York
I don't know how your 1971 is set up, but when I turn off the battery switch on mine, I loose all 12 volt circuits - no lights, fans, furnace, etc. So, if you don't use anything 12 volt and yours is wired like mine, then yes, your battery will last longer!
Ron
2004 Classic 25 - The Silver Sausage
2008 Silverado LTZ CC 2500 4x4 Duramax - Brutus
WBCCI 2623
romap is offline   Reply With Quote
Old 03-31-2008, 03:40 PM   #3
bertro's Avatar
1971 23' Safari
Groveport , Ohio
Thanks for the reply Ron, I went out and checked and all of my 12V systems with the exception of my stereo amp work with the switch off. I just put the switch in yesterday and did not see if the 12V things would work with shore power only. Thanks I could not see the need to keep pumping even a float charge into the battery when not needed. Robert
Old 03-31-2008, 05:59 PM   #4
New Borockton , Alabama
Images: 21
Robert,
If your converter has a float mode (I think I sent you one if I remember) I would not worry at all about leaving it connected. It's not too big a deal if you would feel better not connected but depending on how long you stay disconnected will depend on the amount of self discharge. Figure about 10-15% per month.
Having said that, it's virtually impossible to build significant sulfation on a fully charged battery. That is what you want, full charge as much as possible.
Your not going to gas off on AGM unless its overcharging and then it could vent (actually overpressurize and release). Otherwise it recombines and will last probably 10 years or longer if you talk nice to it.
Randy...Converters, Inverters, Trimetric, Surge Protectors, Zamp Solar, AGM Batteries
www.bestconverter.com
Old 03-31-2008, 06:14 PM   #5
bertro's Avatar
1971 23' Safari
Groveport , Ohio
Thanks Randy, The new paramode has worked out for a nice setup thanks for all of your help. I,m very pleased with your advice on this new 12V system and any AS owner thinking of a rework should contact you. Robert
Master Battery disconnect FishByFly Batteries, Univolts, Converters & Inverters 7 11-20-2007 05:53 PM
Bad Battery Disconnect? Steve & Susan Batteries, Univolts, Converters & Inverters 4 05-07-2007 03:57 PM
automatic tranny disconnect? str8strm Tow Vehicles 4 07-01-2005 12:43 PM
Disconnect Drive Shaft smily Airstream Motorhome Forums 2 02-23-2004 05:51 AM
