Old 05-29-2007, 05:50 AM   #1
1979 31' Excella 500
Detroit Area , Michigan
Images: 43
Digital Panel Voltmeter source
Anybody know of a good source for digital voltmeters which can be installed in a panel type installation? I want to keep better track of what is going on with my battery than 4 LEDs.
wacnstac is offline   Reply With Quote
Old 05-29-2007, 05:54 AM   #2
lewster's Avatar
Naples, FL , Hood River, OR
Check with Randy (68 Overlander) at BestConverter - Inteli-Power, WFCO, Parallax, Inverters, Solar, Electrical Supplies. He sells a battery monitoring device that a member recently added to his coach and LOVES it.
And Randy is a really great guy who knows his stuff!
Old 05-29-2007, 08:00 AM   #3
Images: 43
I kindof wanted a panel type because I have a hole to fill, and I wanted two decimal places after the 12 volts.
Old 05-29-2007, 08:27 AM   #4
INSANITY CENTRAL
doorgunner's Avatar
1986 32' Excella
2014 Interstate Ext. Coach
Citrus Heights , California
Images: 35
digikey.com for all your electronic needs!
www.popasmoke.com
Proud Appellation American
Vine View Heights is now closed.
YETI ( 65 Quart )
IGLOO (Ice Cube, 50 Quart )
doorgunner is offline   Reply With Quote
Old 05-29-2007, 08:33 AM   #5
Always Airstreaming!
rickandsandi's Avatar
2005 22' Safari
1960 24' Tradewind
Anytown , Connecticut
Send a message via AIM to rickandsandi
Originally Posted by lewster
Check with Randy (68 Overlander) at www.bestrvsupply.com. He sells a battery monitoring device that a member recently added to his coach and LOVES it.
Lew-
Link is not working-
Rick
J. Rick Cipot
Sandi Gould
NEU New England Unit
Airstream Life Magazine
Proud Member of WBCCI
WBCCI #3411
AIR #17099
2009 Silverado 2500HD
2004 22' Safari
1960 24' Tradewind
rickandsandi is offline   Reply With Quote
Old 05-29-2007, 12:55 PM   #6
Images: 43
I'm looking for a unit like this eBay: 20V DC WHITE LCD Auto Battery Solar Panel Voltmeter (item 230133517519 end time May-29-07 13:15:58 PDT)
but preferably not on Ebay.
Old 05-29-2007, 01:13 PM   #7
CanoeStream's Avatar
St. Cloud , Minnesota
I fixed Lew's link. Refresh your browser and it should work.
5 meter Langford Nahanni
Old 05-29-2007, 02:04 PM   #8
just jd.
5cats's Avatar
2007 20' Safari SE
San Diego , California
Originally Posted by rickandsandi
Lew-
Rick
BestConverter - Inteli-Power, WFCO, Parallax, Inverters, Solar, Electrical Supplies ??
2007 20' Safari SE/LS // 12063 //CA-5// ("ex") 2916
5cats is offline   Reply With Quote
Old 05-29-2007, 02:18 PM   #9
2005 22' Safari
1960 24' Tradewind
Thanks Bob!
J. Rick Cipot
Sandi Gould
WBCCI #3411
AIR #17099
2004 22' Safari
1960 24' Tradewind
Old 05-29-2007, 02:21 PM   #10
2005 22' Safari
1960 24' Tradewind
Originally Posted by wacnstac
This unit really does not give you any information that is of value. Volts are volts, but if you are concerned about things like; is your battery fully charged, how much power does it have left and what your current consumption is you need a full monitor as Lewster points out. I have spoken with Randy in the past and he really knows his stuff and is always ready to help anyone out.
J. Rick Cipot
Sandi Gould
WBCCI #3411
AIR #17099
2004 22' Safari
1960 24' Tradewind
Old 05-29-2007, 02:31 PM   #11
Images: 43
I don't need to make it complicated. I can tell when my AGM sits at 12.8 volts for 30 minutes after charging and by how long it has been charging that it is good to go. I also have charts which give me a pretty good idea based on voltage how much is left in the battery with no load on it. Just want to find a voltmeter like the one on Ebay. Perhaps I will have to buy that one.
Old 05-29-2007, 07:43 PM   #12
lewster's Avatar
I was just thumbing thru a new supplier's catalog today and saw a nice digital voltmeter from Blue Sea Systems. I don't recall the model or price, but I'm sure that West Marine will either have it or can get it. BSS stuff is of excellent quality, made for the marine industry.
Old 05-29-2007, 08:31 PM   #13
Images: 43
I'm going with one of these from BestConvertor:
Volt Minder
It's simple and I like the idea of an alarm which can wake me up on those nights when the furnace is running if the battery gets too low to start the generator up.
Old 05-30-2007, 06:50 AM   #14
lewster's Avatar
Nice unit.......SUPER PRICE!
replacement panel maznblu Ribs, Skins & Rivets 4 09-18-2002 05:45 PM
Control Panel indicators smily Electrical - Systems, Generators, Batteries & Solar 3 07-26-2002 03:55 PM
Dented panel replaced Jim W Ribs, Skins & Rivets 1 07-08-2002 07:07 PM
Display Panel ALANSD Mechanics Corner - Engines, Transmission & More... 4 06-08-2002 03:28 PM
61 Bambi Panel Replacement 61BambiCanada Ribs, Skins & Rivets 0 06-07-2002 09:41 AM
