Old 03-29-2009, 08:35 PM   #1
WineStream's Avatar
2005 30' Safari
Pleasanton , California
Images: 24
definition of inverter? why no 120VAC when unplugged from city current?
Jason, the electrical klutz speaking once again...
Isn't the definition and "job" of an inverter to change battery DC power into 120VAC power (yea, with lots of conversions factors and ratios). Shouldn't one if not all of my 120VAC outlets in the AS have juice to them when I'm disconnected from city / house 120VAC? I figured that I'd at least be able to get an hour of TV / DVD out of the on-board battery and inverter, but when I pull the 120 plug, everything 120 is gone.
Is everyone else's trailer a 12VDC-only trainer when the umbilical is yanked or is it just me?
WineStream is offline   Reply With Quote
Old 03-29-2009, 08:53 PM   #2
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
Jason,
You got it, unless someone installed an inverter, only have 12V power when not plugged into a 120V outlet. Your trailer has a convertor which keeps the batteries charged when plugged in.
Bill
Just my personal opinion
Old 03-29-2009, 10:12 PM   #3
FLYNCLD's Avatar
1962 22' Flying Cloud
Bend , Oregon
In order to do both, you need an INVERTER, which inverts 12VDC to 120V AC, and a CONVERTER which converts 120VAC to 12VDC. The size of the INVERTER you need depends on how many 120V appliances you wish to run, and how much 12V power (i.e. batteries) you have to work with.
FLYNCLD is offline   Reply With Quote
Old 03-30-2009, 07:47 PM   #4
WineStream's Avatar
2005 30' Safari
Images: 24
my bad I guess. I thought the Univolt IS an inverter as well. I looked at it again and I see it says "power supply." I guess I misconstrued that as a 120VAC power supply...apparently not the case, though.
Old 03-30-2009, 07:57 PM   #5
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
Trailers come set up from the factory to provide 12 volt power to a few select items ie: furnace blower, fridge, water pump and some lights and special plugs (look like cigarette lighters). It comes with a CONVERTER to convert the 120v power to 12 volts. It DOES NOT come with an INVERTER which goes the other way (12 volt to 120volt) You can install an inverter, however it will not power a 120volt anything for very long on battery power only. The rest of the stuff runs on 120volt ONLY when you are plugged in to shore power.
Aaron
WBCCI #XXXX AIR #2495
Old 03-30-2009, 08:17 PM   #6
1986 31' Sovereign
Miami , Florida
Atobols,
Try reading this: Inverters by phred
pretty good primer...
mike
Old 06-04-2009, 01:37 PM   #7
Islander
kingfisher24's Avatar
2005 28' International CCD
Deer Harbor , ORCAS ISLAND WA
inverter intergration into coach's system
any experience in installing an inverter so as to intergrate it into the electric system of coach to allow ALL convience 110 v outlets to become live receptacles using only the 12DC power as supplied by batteries and recharged by solar application or generator or tow vehicle alternator???
kingfisher24 is offline   Reply With Quote
Old 06-04-2009, 01:58 PM   #8
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
Kingfisher24,
Colin Hyde has a method of doing what you want. As I remember, it takes some rewiring and one expensive switch. Email or phone the VAP with your question, as Colin does not check in here very often.
Bill
Airstream motorhome 120vac operation bkahler Classic Motorhomes 9 03-01-2018 04:52 AM
Television 12vdc/120vac operation Roadmeister Audio, Video & TV 26 08-24-2007 03:49 PM
Definition of Frustration... GT1963 Off Topic Forum 27 04-08-2004 11:44 AM
What is definition of 'fulltiming?' yukionna Full-Timing 7 10-14-2003 05:49 AM
