Old 06-17-2013, 07:47 AM   #15
2004 25' Safari
Laramie , Wyoming
If not, do any of your wall outlets have a small blue label on them? Especially near your television(s)?
No, no outlets with blue lables, so I am guessing that I don't have any 12 volt outlet. I do have a unusual outlet that is where my cable for the television plugs in. Just above the cable there is what looks like a 12volt outlet(1" wide and round)that says voc 8 amp max on it. I am assuming that it has something to do with the boobtube.
mgap is offline   Reply With Quote
Old 06-17-2013, 09:33 AM   #16
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
That round thing is a 12 volt accessory outlet. You can plug in things like cell phone car chargers and if you find a 12-volt flatscreen that would probably be more efficient than having an inverter powering a 120-volt TV anyway.
David
Old 06-17-2013, 05:09 PM   #17
2004 25' Safari
Laramie , Wyoming
Thanks for the information. Hmm I wonder if I could plug my laptop computer in for a charge on that one?
Old 06-17-2013, 05:21 PM   #18
retired USA/USAF
2001 30' Excella
Somerset , New Jersey
I just looked at the charger for my Mac-book. It says 15 amp. but that's through a
130-240 v outlet. If you have a 12v charger check what the draw is. It might work.
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
polarlyse is offline   Reply With Quote
Old 06-17-2013, 05:46 PM   #19
DKB_SATX's Avatar
1976 Argosy 28
Magsafe output should be 85 watts... which comes in just under the 8A at 12V listed on that outlet. Since you're really generally dealing with 12.7 volts or more, it should be a little under 7A assuming 100% efficiency, so there's a little wiggle room.
Even 1.5A at 120v is 180W... more than double what they list as the nominal rating of the Magsafe 2 adapter.
David
Old 06-26-2013, 08:40 PM   #20
2005 22' Safari
Half Moon Bay , California
Recommend solar battery charging, and inverter for 110 volts for charging laptop computer. 12 volts is marginal. Generally for boondocking avoid electrical use unless you have a solar charger. Anything requiring heat is more efficient with propane - french press or filter drip coffee works great with a kettle on the stove.
jsutro is offline   Reply With Quote
