I guess the triad converter in my 76 has finally died. Power to the plug under the sink were it plugs to 110, but not even the annoying hum that I've hated all these years. Below are pictures of mounted unit after I pulled the stove out, the fuse panel behind the sliding door, and the top of the converter after being pulled out and placed on end on floor. ( and that baby is heavy)No wiring has been disconnected at this time except for battery cables from the battery and Triad unplugged.
Looking at an
Intelli-power 45amp replacement unit.
Questions:
I only have one
12 volt battery and use this AS at deer camp year round hooked to shore power. Will the 45 amp be enough?
Three cables leave the old Triad... Two black to the back of the fuse panel and one small white that I believe is a ground as it splits and one leg is grounded to AS body. Will I need new wiring from the new unit to the Fuse panel or can I use the wiring between the Old Triad and the fuse panel? Do you drill out the rivets on the Triad to unmount wiring from inside?
Which brings up the question..can I still use the current fuse panel?
Thanks in advance for any and all answers or comments.
