Old 06-10-2013, 06:32 PM   #1
Jeff
jkinglet's Avatar
2013 Interstate Coach
Seattle , Washington
Images: 37
Dead Converter?
2009 20' Flying Cloud with an electricity idiot at the helm. Here's the problem. Simply put: No battery charge at all from shore power or when plugged into the generator with the 30 amp cord. Five days in one spot dry camping with my Honda 2000ui is how I found out. 7-pin trailer-to-truck plug charged the batteries enough so I didn't have to shorten the trip. New batteries by the way. Plugged into shore power on return..no charge, no converter fan noise. Parralax (sp) converter. Can anyone target most likely places to check for gremlins considering, of course, my total lack of electrical knowledge? Somebody mentioned ground wires shaking loose? Thanks. Jeff
jkinglet is offline   Reply With Quote
Old 06-10-2013, 06:43 PM   #2
PhilipKS's Avatar
1999 34' Excella
NE Central , Kansas
First things first....is everything else on the circuit working? Have you checked your circuit breakers? And is battery switch set to the 'on' position, not in standby or off? If you do need to replace the converter, go to www.bestconverter.com with the model you currently have, and they will suggest the best replacement, of which there are several good ones.
AIR 57698, TAC NM-9. http://www.flickr.com/photos/philipks/
PhilipKS is offline   Reply With Quote
Old 06-10-2013, 06:43 PM   #3
1976 31' Sovereign
Oswego , Illinois
Smile dead converter
If you have 12 volt power from truck check 110 circuit breakers may be the prob.
Old 06-10-2013, 07:02 PM   #4
Jeff
jkinglet's Avatar
Images: 37
Checked all of the circuit breakers..looked good. battery switch in correct position, everything else is working fine. Just no charge to the batteries.
Old 06-10-2013, 07:06 PM   #5
daveswenson's Avatar
2012 28' International
Issaquah , Washington
Maybe a dumb question. What is telling you that the batteries are not charging?
Dave
2014 Ram 2500 CTD
Pro Pride
Centramatics
daveswenson is offline   Reply With Quote
Old 06-10-2013, 08:44 PM   #6
1976 31' Sovereign
Oswego , Illinois
Smile
cannot always tell if breakers are tripped by looking, manually reset them if did not cure probs. then continue checking every thing
Old 06-11-2013, 06:15 PM   #7
Jeff
jkinglet's Avatar
Images: 37
Thanks for the thread. Double checked everything today including resetting the breakers, and checked all the voltages with a multimeter. Tightened up a loose converter ground wire as well (screw almost all the way out). VDC 12.10 at the batteries, plugged in. About the same unplugged. 120AC good coming into converter. VDC leaving converter read 20.0 (manual says it should be lower) batteries isolated. Battery charge was creeping up when I left (someone mentioned it should read 13.5 VDC with the trailer plugged in). Left plugged in for the overnight and will check all the voltages again in the a.m. The new batteries, installed by the dealer last month, are Interstate SRM 24 and from the looks of the online reports, that battery is not the strongest deep cycle on the planet, especially for boondocking (what I do a lot of). Optima Blue Tops perhaps? About ready to pull the fuse on the stereo (that starts up every time by itself when I switched from "store" to "use".
Old 06-11-2013, 06:47 PM   #8
It sounds like the 20v leaving the converter isn't getting to the batteries. Maybe a bad cable? or connections between the converter and the battery? I wouldn't think the batteries would be bad already.
Dave
2014 Ram 2500 CTD
Pro Pride
Centramatics
Old 06-11-2013, 07:11 PM   #9
Probably a dumb question. You checked the fuses?
Dave
2014 Ram 2500 CTD
Pro Pride
Centramatics
Old 06-11-2013, 07:22 PM   #10
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
Dumber question: batteries full of water/electrolyte?
Old 06-11-2013, 09:11 PM   #11
Jeff
jkinglet's Avatar
Images: 37
yep and yep.
Old 06-11-2013, 10:10 PM   #12
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
20V leaving the converter seems like a problem. I would consider a converter-charter that outputs 20v to be a paperweight, or an anchor.
I realize that old clunkers like the ancient Univolts produce unpredictable results without a battery in the system, but I think modern ones, even the single-stage battery killers, shouldn't do that.
— David
DKB_SATX is online now   Reply With Quote
Old 06-12-2013, 04:46 AM   #13
CLOUDSPLITTER "Tahawas"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
My suggestion......
Give Randy a call at Best Converter. He will give the straight scoop on converter and battery replacement.
I changed out the OEM Parallax converter after installing two grp27 Lifeline AGM batteries. Along with LED replacements in all high use interior lights, the best boondocking upgrade we've done, much longer battery use.
PFC
but I’m the Husband, so we went to Cleveland. 😂
RLC
Step aside Starbucks, this is a job for alcohol.
Old 07-21-2013, 04:15 PM   #14
Jeff
jkinglet's Avatar
Images: 37
If anyone cares, this issue was resolved with a 4-stage, 45amp Progressive Dynamics charger ("Our patented Charge Wizard® 4-stage system constantly monitors RV batteries and automatically adjusts your converter output voltage". in place of the charger unit in the 7300 series Parallax that went belly up. A little pricey but worth it. Works like a charm. Added a pair of Optima (AGM) Blue Top Deep cycle batteries to the equation. Boondocking here I come. Add a recently serviced Honda EU2000i and it all works. Mechanic found a pair of large wood screws from nowhere (one welded to the element) that were left rattling around in the parallax charger area and shorted it out (toast).
