Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar > Batteries, Univolts, Converters & Inverters
Old 03-19-2006, 02:48 PM   #1
Silverhobby's Avatar
Profile:  1956 26' Cruiser/Overlander
1957 26' Overlander
1962 22' Flying Cloud
Vale , North Carolina
Dead Battery
Hi Group,
I just went out to check the A/S. It is a 1972 29 foot Ambassador. The coach battery was dead. I plugged into A/C current to see if I had left any lights or anything 12 volt on. Nothing was turned on. Is there something I can check to see what is draining my battery when there are no obvious signs of 12 volt usage? Kev
Old 03-19-2006, 02:58 PM   #2
balrgn's Avatar
Profile:  1974 27' Overlander
Rockingham County , New Hampshire
Images: 74
Send a message via AIM to balrgn Send a message via Yahoo to balrgn
Originally Posted by Silverhobby
Hi Group,
How long was it setting there? May have just drained down....
'74 Overlander (T-O-Bee)
'46 Spartan Manor (Rosie)
2006 GMC Sierra 5.3 V8
WBCCI 1754 - AIR # 6281
Member of VAC
www.balrgn.com
www.balrgn.com/Airstream.htm
balrgn is offline   Reply With Quote
Old 03-19-2006, 03:16 PM   #3
Rivet Monster
wahoonc's Avatar
Profile:  1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 35
Kev,
Do you have a newer fridge? They have a constant on 12 volt controller. A quick way to check for drain is to make sure everything is off, then disconnect the ground cable from the battery, put a test meter or light in between the post and the cable, if you get light or a reading something, somewhere is pulling current. It could be a intermittent short, or a high resistance short, something as arcane as wire strands in the tow plug touching. With the older units with many miles on them electrical gremlins can be a fact of life. The best bet in the future is to disconnect the battery if it is going to sit for more than a week. Mine has a handy plug in the battery compartment that just pulls apart. You could also add a battery disconnect very easily, look in race car supply shops or Marine/boating supply shops for ideas on what is available.
Aaron
WBCCI #2449 AIR #2495
wahoonc is online now   Reply With Quote
Old 03-19-2006, 03:24 PM   #4
balrgn's Avatar
Images: 74
Yup, Arron, an isolator is a nice thing. Can get them at a Boat supply
Somethin like this
Member of VAC
www.balrgn.com
Old 03-19-2006, 07:44 PM   #5
Profile:  1976 25' Caravanner
Campton , New Hampshire
Do you have a trunk light?
ticki2 is offline   Reply With Quote
Old 03-20-2006, 09:24 AM   #6
1957 26' Overlander
Thanks for the great ideas. I do have baggage compartment lights. I'll have to make certain they go off when I shut the door. That always happens in the fridge, right? I have the older manual control fridge, so, no 12 volt power there. I'll keep searching, but I am sure an electrical disconnect would be money well spent. Kev
Old 03-22-2006, 01:36 AM   #7
azflycaster's Avatar
Profile:  1975 25' Tradewind
Phoenix , Arizona
Images: 65
Airstream Registry
If you have a CO or propane detector, they can drain your battery. If you charge your battery and then remove one of the cables and touch it to the post (the one you removed it from), you should not see any spark if everything is off. If it does spark, something is on. Don't be plugged into shore power when you do this. You can use a meter, but this is easier.
Richard
Charter Member Four Corners Unit
azflycaster is online now   Reply With Quote
Battery Location uwe 1970-79 Tradewind 22 09-04-2003 07:44 PM
Battery Dead - Again & Again eraffety Airstream Motorhome Forums 10 11-01-2002 11:03 PM
igniton switch and the mystery of the dead battery Curtis-79MH Airstream Motorhome Forums 3 10-25-2002 02:58 PM
Extra Battery Placement JaceBeck 1999 Safari 16 10-02-2002 01:03 PM
Battery Dead/Power jack question jcanavera Jacks, Stabilizers, Lifting and Leveling 34 08-16-2002 01:51 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
