Old 10-22-2015, 05:35 PM   #1
Hot Springs , Arkansas
Dead Battery
A newbie question. We put our slightly used but new to us 14 Classic in our storage building about 4 weeks ago, with the battery monitor showing Full and all systems working properly (lights, jack pumps) on battery. All were turned off - we think, but the battery disconnect was not turned off.
Today I went to have our satellite installed and found the Battery dead. The jack would not respond, the lights wouldn't come on, nor would the systems monitor.
I plugged the unit in to the AC power and the lights immediately worked. After a few minutes I checked the jack and it did not respond. I checked the monitor and the Battery showed Full.
Battery management is one of many systems we have to learn. Does all this sound normal? Should the batteries be dead in 4 weeks? How long will it take to recharge the Batteries? Water levels are full in each.
Thanks.
Johndews is online now   Reply With Quote
Old 10-22-2015, 06:03 PM   #2
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
1. The stock battery monitor will not show true battery condition when connected to shore power. You must disconnect shore power for several hours and then check the battery. Even then, the stock battery monitor is, at best, rudimentary. Measuring the voltage with an inexpensive digital voltmeter and comparing it to a charge status chart for the type of battery you have is better. An actual charge discharge monitor is better.
2. I don't know specifically about your trailer, but on my 2001, the disconnect switch leaves the propane detector connected. The newer ones only draw about .04 Amps, or about an Amp-hour per day. If you have two group 24 batteries you should have about 170 Amp-hours of total capacity, but should only plan on using 50% of that to avoid battery damage. So good batteries running only a propane detector should still work after 6 weeks to 2 months. Since you didn't turn off the disconnect switch, I can't say how long it should have gone - another member will have some ideas. Refrigerator, furnace, stereo, TV, are all possible parasitic drains. Storage compartment lights are famous for getting bumped on during travels. The bulbs in my trailer drew 2 amps. Only one such light left on would drain your batteries in less than a week.
3. It is not uncommon for trailers which have been left on shore power for extended periods using the stock converter-charger to have damaged batteries.
4. The best test is to hook up to shore power for several hours or overnight. Then disconnect the shore power and periodically test the battery condition with the monitor panel or a voltmeter.
5. Your jack should have worked once shore power was connected. If it didn't you may have an intermittent wiring problem. Mine worked fine for several months and then quit. The negative cable from the jack pulled out of its connection on the battery negative bussbar.
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Old 10-23-2015, 02:00 PM   #3
Thanks Al and Missy. Went back today, disconnected shore power and all systems seem good, including tongue jack. Turned battery disconnect off and hope we are good to go. Thanks again!
Old 10-23-2015, 03:21 PM   #4
Goal15's Avatar
Dallas , Texas
Also,make sure the radio/cd player is off. first year i made the mistake of turning the battery switch to store, then flipped it back on for some reason then off again but discovered that flipping it back on turned on the radio/cd player and it rain my battery down.
Dana
Dana and Olga
2006 Safari 23
2011 Tundra Double Cab
Goal15 is offline   Reply With Quote
dead dead bolt Jim from SB Doors & Locks 3 09-09-2012 11:32 AM
Dead ...really dead Melody Ranch Batteries, Univolts, Converters & Inverters 17 06-13-2007 12:23 AM
dead battery-revisited PeterH-Airstreamer Airstream Motorhome Forums 41 12-12-2002 06:38 PM
igniton switch and the mystery of the dead battery Curtis-79MH Airstream Motorhome Forums 3 10-25-2002 02:58 PM
Battery Dead/Power jack question jcanavera Jacks, Stabilizers, Lifting and Leveling 34 08-16-2002 01:51 PM
