02-12-2016, 02:56 PM
#41
2017 25' International
Carlsbad
Along the lines. I too have had the dead battery syndrome. Maybe because they weren't properly charged before I stored. So I have new pd4655, but probably didn't get enough on the batteries. Seelevel read 12.4 and I added 5 watt solar on propane tank cover directly to batteries. AS in store mode. 2 weeks later, Seelevel reads 11.4.
Now on shore power for 4 straight days, water level checked all cells. I will be storing 4 weeks to next trip. I think I'd prefer to disconnect negative terminal this time. BUT,
I see 2 harnesses leaving the battery compartment. Each has a connection to one battery or the other grp24.
I assume one is inbound from PD4655 and the other is the one I need to disconnect. For the prize, which one.....
02-12-2016, 04:00 PM
#42
2015 25' FB International
Quick reply: My AS is almost never in "use" mode. Not on the road, not when hooked to shore power. Only when I go to pick her up out of the storage unit or putting her back in.
Am I being told that I'm never charging my batteries?
02-12-2016, 04:10 PM
#43
1974 Argosy 20
Kooskia
, Idaho
You are only charging your batteries when the switch is in USE mode and you are connected to grid power.
Also, while you are towing, but only if your tow vehicle is set up right. Contrary to what has been said in one of the posts above, the USE/STORE switch does not change the tow vehicle charging.
02-12-2016, 10:02 PM
#44
Then there is absolutely NO reason that it should be called "store" mode. The relabeling shall begin!
02-12-2016, 10:20 PM
#45
Here's how it's going to look!
02-13-2016, 06:37 AM
#46
2020 28' Flying Cloud
Upper St Clair
, Pennsylvania
The switch does not change the charging of the tow vehicle, but it does not allow the trailer to charge the batteries if in the OFF position.
From your picture in the last post when my switch is in use the light is red. When it's in store mode it's clear.
2020 28' Twin Flying Cloud
2021 F350 6.7 King Ranch
USAF Master Training Instructor (TI) & (MTI)- 68-72
Volunteer K9 Rehabilitator & Trainer
02-13-2016, 03:08 PM
#47
Right. That's a black and white photo that appears to have the light on.
02-26-2016, 05:07 PM
#48
2016 16' Sport
Santa Barbara
I'm a newbie with a 2016 Bambi. I'm not an electrician. Most times I can't spell the word. Anyway here is my issue. My AS is parked right next to my business so every morning I go out and plug in a Solar panel and charger I got from Renogy. I charges most of the day at around 30 watts and somewhere between 11.5 and 13 volts. At the end of the day my battery readout says I have 12.6 to 12.8-9 volts which I understand is full charge. The next morning I come in and check the voltage and it has dropped to the low 12s or high 11s. This seems weird to me. I have been told not to run it below 11.6 so it's almost discharged every am. Everything I can find to turn off is off except propane detector. Is this normal or does anyone think I have a leak or short or whatever. All help appreciated. Thanks
Steve
03-04-2016, 01:34 PM
#49
2008 23' Safari SE
Oklahoma City
, Oklahoma
Putting a batteryMinder on my batteries tomorrow because of these issues.
03-19-2016, 09:00 PM
#50
UPDATE: De-winterized and went on the first trip. Batteries were so dead I had to hook up the umbilical just to get the power Jack to raise. After a two hour drive, batteries back to 12 and holding steady. Returned to storage and went back a week later to check... 11.9v. Go figure! So great to be on the road again.
03-20-2016, 05:47 AM
#51
Sag Harbor
, New York
Are you batteries the original ones, and are they still under warranty? You might consider asking the dealer for replacement batteries IMO, if the facts warrant.
03-20-2016, 06:45 PM
#52
I might ask. They're holding a charge now though so I would guess a bench test would reveal them to be in fine condition and unwarranteeable. (If that's a word).
03-20-2016, 08:07 PM
#53
2013 31' Classic
billings
, Montana
After charging, leave one cable unhooked until you need to use, you will know if battery are goog.. My batteries will go south in about 1.5 weeks...
03-20-2016, 09:16 PM
#54
I don't think I've ever touched something electrical and not gotten shocked. It's a risk / reward thing!
03-20-2016, 09:27 PM
#55
Walnut Creek
You need a battery disconnect switch to kill the parasitic drain when you store the coach. The marine supply stores sell them. Pat
06-04-2016, 02:31 PM
#56
2008 22' Safari
Spicewood (W of Austin)
I notice a lot of late-model owners are reluctant to keep the battery in "use" (ON or Charging) mode when stored and hooked up to shore power.
If your Airstream is a later model (mine is a 2008) it is likely equipped with a multi-stage power supply and will "taper" or "trickle/maintain" charge your battery if it's kept in "use" (ON) mode, just fine. Check your battery water level every few months or so.
Only if you do NOT have a multi-stage power supply would it make any sense to disconnect the battery when hooked up to shore power.
The "store" position has almost no valid use other than to remove it from shore power re-charge circuit because of a defective or single-stage power supply when the coach is not being used for any purpose. (And even then, I cannot figure out why a propane detector should be continually powered when the vehicle is disabled in storage and no one is around to hear the detector.)
(I agree that a battery minder hooked up to a disconnected battery is a good idea for those with older, single-stage chargers/pwr-supplies.... but again, if the battery is disconnected and no shore power...then there's no propane detection going on either.... so why would it be req'd to be powered if no one is around simply because the battery is connected?) (Ans. NOT)
06-04-2016, 04:50 PM
#57
2015 30' Classic
Pleasanton
The Use/Store switch is useful for folks who boondock and are not connected to shore power. When they leave the trailer, they can simply select Store and know that all their loads are disconnected. I have a 2015 Classic and Airstream still only supplied me with single-stage converter - so the Store/Use switch is also used to isolate the converter when connected to shore power.
Now, given there's utility in the Store/Use switch, if I had to choose where to connect the propane detector I would probably keep it connected to the batteries. Why? Because although the probability of having an LP leak is low, the consequence is fatal, so connecting the detector directly to the batteries avoids the case where someone is in the trailer and left the Store/Use switch in the Store position, or there was a failure of the battery disconnect relay. Either way, when the consequence is fatal, the detector should be powered from the most reliable source.
Al, K6IV
2015 30' Classic, "Chez Nu"
2014 RAM 2500 w/Cummins Diesel
ProPride Hitch, 400 W Solar
06-04-2016, 07:15 PM
#58
Naples
Airstream is still using the single voltage 'dumb' power converters to charge their OEM Interstate batteries.
To my knowledge, they have NEVER used a multi stage converter in any trailer except for a few selected 22 Sport models.
Every Airstream trailer I have worked on, including a new '16 FC 28 still use the Parallax converter with the 13.6 VDC constant output.
Lew Farber
ABYC Certified Master Marine Electrician
AM Solar Certified Installation Center*AMS Lithium Batteries
Lifeline AGM Batteries**Magnum Inverters***Victron Energy Components
541-490-6357
lewster
06-06-2016, 01:50 PM
#59
Alamo Heights
Re: Boondocking: Most newer trailers with a store/use switch require 12v to keep the fridge running, and putting it in Store cuts that off.
David
Zero Gravitas 2017 Flying Cloud 26U | WBCCI# 15566
06-08-2016, 09:18 AM
#60
2008 22' Safari
Lew Farber
541-490-6357
Thanks for the edjamacation, Lew.
Those owners who have older single-stage converters might like this option:
http://www.rvforum.net/miscfiles/Mag...tructional.pdf
