03-18-2019, 06:51 PM
2017 27' Flying Cloud
Ocala
Dead Batteries - question
I have a 2017 27 FB bought new. I have a 30amp hook up at home which I leave it plugged into. Last used 2 months ago. I went to look over the camper today and noticed the batteries were dead. I have used it about 80+ nights and used to just use the battery disconnect on the neg terminal at home prior to installing the 30amp service at the house.
I thought, perhaps mistakenly the shore power would keep them charged.
Please oh wise ones... explain it to me.
I currently have a battery charger on them and it is unhooked from the 30 amp supply.
What else should I be aware of -- I plan on camping in 3 days
Thank you in advance
Mike
03-18-2019, 06:55 PM
Sag Harbor
, New York
Did you have the Use/Store switch on Use? Necessary for charging batteries. What does your owner’s manual say about this switch? [assumimg your model is so equipped]
“Use Store Switch” Search results for other threads and posts:
https://www.google.com/search?q=Use+...=airforums.com
You should have the batteries tested, because you may have ruined them by letting them go dead. Are they the original batteries? Just get new ones IMO.
Good luck,
Peter
03-18-2019, 06:56 PM
Ocala
It is on use
03-18-2019, 07:16 PM
Sag Harbor
, New York
Maybe your charger/converter went bad? Does your battery monitor show about 13.7 volts when on shore power?
Are you sure the 30 amp service was on? Did other 120 volt things like outlets work? Is the circuit breaker for the converter/charger on?
Diagnosing this is above my pay grade so I will bow out.
Good luck,
Peter
03-18-2019, 09:44 PM
Paradise
I bet you cooked your batteries.
Is there any water left in them?
A proper 3 stage charger is necessary for long battery life, whatever the type , but more importantly with agm.
03-19-2019, 09:51 AM
Fernandina Beach
, FL
Time for new ones
I have the same trailer. My first set of Interstates crapped out in 2018.
If I understand your process, you are disconnecting the negative ground before storing the trailer with 30 amp shore power. I think this allows the batteries to sit without a charge. That might cause them to fall below 12v, which will kill the batteries.
I suggest you get new batteries, and reconsider your storage approach.
03-19-2019, 10:41 AM
Rockaway
, New Jersey
Sorry to hear this.
I also have a 2017 FC27FB, and have a 30 amp service at home. I heard that leaving it plugged in constantly will "cook the batteries" by overheating them and boiling off the water. So I would check the water levels. If it is below the plates, you will definitely need new batteries.
What I did this winter is just leave the batteries connected as usual and put the trailer on "store". The factory solar would usually maintain them above 12.7. However, if we had a string of cold cloudy days, I would put the unit on "use" and plug into the 30 amp overnight which would get them back up to at least 13.2. I never left plugged in longer than 24 hours.
This seems to work and this method was also confirmed as a good choice by Colonial Airstream.
"I thought growing old would take longer"
03-19-2019, 11:10 AM
2018 27' Globetrotter
Apollo Beach
If I were planning to leave my 2017 Airstream plugged in at home, I would replace the stock converter with a PD4655 from www.bestconverter.com so it drops into float stage when the batteries are fully charged. I would also just buy new batteries as my original batteries only lasted for ten months.
I replaced my batteries with a pair of 6V Duracell golf cart batteries from Sam's Club, installed the PD4655 and 400W of solar to keep my batteries fully charged in storage and when dry camping. My Duracell 6V golf cart batteries still test as new after about the same time and usage it took to murder my Interstates. To install 6V batteries requires one larger battery cable connecting the positive post from one battery to the negative post on the other battery. Here is a picture of my battery installation: http://www.airforums.com/forums/atta...2&d=1521682083
2021 Northern-Lite 10-2 & F350 DRW PSD, 600W Solar/Victron/600A BattleBorn
146 nights 31,000 miles (first 10 months!)
Sold: 2018 GT27Q, 74 nights 12,777 miles
Sold: 2017 FC25FB, 316 nights 40,150 miles
Sold: 2013 Casita SD17 89 nights 16,200 miles
03-19-2019, 12:46 PM
FLHTK & FXDWG
2003 25' Safari
Ridgeville
, South Carolina
First don't feel bad, we all have trashed batteries. When I first got my AS I left it plugged in and cooked the crap out of my batteries. Then we installed a 3 stage charger. Every time I got home from camping I would disconnect one of the terminals to make sure nothing drained them. Those AGM lasted for 5+ years until I forgot to disconnect them before putting up for the winter. If a few months go by and I haven't used it, I will throw a little charge on them with another AGM charger or connect the AS cables and plug it in for the weekend. Get a DC meter and listen to what your batteries are saying to you
Ron & Tina
08 F250 4x4 w/FXDWG
03 25' Safari w/Hensley
03-19-2019, 01:07 PM
2016 30' International
Quartz Hill
I would guess that you fried the batteries by leaving them plugged into shore power all the time. Your Airstream needs to be equipped with a multi stage converter to keep from overcharging the batteries. I am not sure but the new Airstreams I believe are equipped with multi stage converters.
A simple solution is to purchase a Battery Tender from Amazon or your local auto parts store. Hook it to your batteries at home and forget about them until you are ready to hit the road. It is a battery maintainer. It charges at 1.5 amps I believe. When batteries are fully charged it automatically shuts down. It then maintains the batteries at full charge. My Battery Tender has dual sets of leads to maintain both batteries at once.
Trash your current batteries and buy new.
03-19-2019, 01:42 PM
Napa
We've killed all sorts of Interstate batteries over the years, they seem to have a prety short life. We discovered the addition of a BatteryMinder (trickle charger) really did help quite a bit. This time however on the Airstream, we have opted for solar and dry batteries and so far it has been a wise decision on our part. While you are traveling keep in mind that Costco usually has Interstate batteris in stock!
03-19-2019, 03:51 PM
Toaster Life
2010 23' International
Tucson
We love our Airstream, but over the years we have gone through a LOT of battery replacements for different reasons - currently we have ours hooked up to a solar charger, and if it works as it should, it charges and floats - we won't know till our next journey if it is working properly or not - replacing batteries has become one of our more routine maintenance jobs. No power at the site where we store it, pulling the batteries from the tight box is a pain...
03-19-2019, 05:25 PM
2018 Basecamp
Fairview
, TX
Yep , sounds like you cooked your batteries. I use a Ctek battery conditioner/charger. It will monitor your battery condition and adjust the charging and conditioning so your battery will alway be in optimum condition but not necessarily at FULL charge.
03-31-2019, 09:56 AM
2017 Basecamp
Albuquerque
, New Mexico
Welcome to the club. I left mine connected while on shorepower at home for a couple months and thought everything would be fine since it was charging 13.6V. Nope. Cooked the water down and they did not recover when refilled and charged. I’ve since put solar on which has been a great solution. When at the house I plug into shorepower but disconnect the batteries. The solar charger does a great job charging and floating them as necessary so they are always ready to go and not getting fried...
03-31-2019, 12:32 PM
2017 28' Flying Cloud
2014 25' FB Flying Cloud
2008 25' Safari FB SE
, Texas & Wyoming
If you look here on the Forum, you will see several threads on this, especially recently....likely your converter cooked your batteries...many of us have had this happen. You can get your batteries replaced by Interstate likely, but if you don't check the source, it can happen again...many of us have replaced the stock AS converter with a Progressive Dynamics 4 stage smart converter or Boondocker with smart technology. Check out Bestconverter.com and call Randy for more advise.
Many of us also install a mechanical kill switch to totally disconnect the batteries when storing for more then a few days, to be safe. When plugged in with the newer converter, you can still operate all internal electronics, even with the batteries disconnected. Good luck.
03-31-2019, 01:59 PM
2017 23' Flying Cloud
Hampden
, Maine
Yep, a battery maintainer is a good way to go. It's low cost and won't damage the battery. Living in cold country, I remove the batteries in winter, bring them indoors and hook up the maintainer periodically, or one can leave it hooked up and let it trickle charge; however, I think it's more economical to do the former.
03-31-2019, 03:06 PM
Phoenix
, Maryland
Does anyone know if the inverter has to be in the on position when on 30 amp service in order to charge the batteries?
03-31-2019, 03:23 PM
2013 20' Flying Cloud
2014 16' Sport
2019 23' Flying Cloud
Dunedin
How old are they batteries? I got a new Airsteam with two year old batteries in it.
“I haven’t been everywhere, but it’s on my list”.
Rosalita WBCCI #12814
Florida Unit #027, Southeastern Camping Unit #012, Florida Suncoast #129, Stella's Sisters, Grapes & Grains, Indie Streamers Save
03-31-2019, 06:55 PM
2018 30' Classic
Jacksonville
Converter makes 12 vdc .
Inverter makes 110vac.
Batteries are 12vdc.
