Old 06-18-2009, 02:23 PM   #1
1971 27' Overlander
maricopa , Arizona
Cut power cord dilemna?
just purchased a '71 27' overlander. The 30a power cord male plug was cut away from the cord. Took the stripped end and fed it into a plugged extension which rand into a socket that only supplied 15amps. However i made sure the AC was turned off. The battery was removed from the trailer. Managed to get the all electric fridge to work but no intirior lights?? reattached the battery and the intirior light come on with no cord attachment? Do I have to have a 30Amp socket to plug into just to get the interior light on. Do i have to have a function battery attached to trailer to have interior lights. Like i said NEWBIE
neokans is offline   Reply With Quote
Old 06-18-2009, 02:36 PM   #2
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
newbie here.
Greetings neokans!
Welcome to the Forums and the world of Vintage Overlander ownership!
There is usually a reason behind the removal of the plug from an RV cord, and my suggestion would be to examine the 120-Volt AC system. My suspicion is that there is likely a ground or neutral problem in the wiring that may be allowing the coach's skin to become electrically charged when connected to shore power. When the problem is located and corrected, the 30-AMP RV plug is available through most RV dealerships -- or a new power cord could be installed depending upon the condition of the existing cable.
This can be anticipated since all of the interior lights are 12-Volt DC. From this information, it would appear that the Univolt (power converter -- 120-Volt AC to 12-Volt DC) is either missing/inoperable, unplugged, or one or more critical fuses/circuit breakers are tripped.
Shore power is not required for the interior lights to funtion as well as the vent fans, water pump, range vent fan, and furnace blower -- all of these devices are 12-Volt DC and operate off of the Univolt when shore power is available or the onboard battery if shore power is not available -- they may also draw power from your tow vehicle if the charge line is properly connected to the tow vehicle's electric system.
The only features on your coach that require shore power are those that require 120-Volt AC to operate. The AC only items would include the air conditioner, electric side of water heater (if so equipped), Univolt power converter, and household type electrical outlets.
Good luck with finding your electrical gremlins!
Kevin
Kevin D. Allen
AIR #827
Old 06-18-2009, 02:39 PM   #3
1971 27' Overlander
maricopa , Arizona
Thanks plenty. Have some starting ground now.
Old 06-18-2009, 03:44 PM   #4
easyride's Avatar
1977 27' Overlander
1963 19' Globetrotter
Naples , Florida
Welcome to the forum,seems someone here will always have the right answer.Dave
easyride is offline   Reply With Quote
Power Cord replacement, 1959 Tradewind plowboy Electrical - Systems, Generators, Batteries & Solar 16 12-31-2013 04:03 PM
Power cord: Where to find STERELLIE Electrical - Systems, Generators, Batteries & Solar 13 06-03-2009 11:50 PM
Shore power cord FreshAir Electrical - Systems, Generators, Batteries & Solar 18 02-21-2007 02:41 PM
Stand up power cord Happycampers Electrical - Systems, Generators, Batteries & Solar 0 04-18-2004 07:03 AM
Hot Power Cord GoldFever Electrical - Systems, Generators, Batteries & Solar 7 07-13-2003 05:49 PM
