Old 01-12-2020, 07:01 PM   #1
streamvizsla's Avatar
2019 27' Globetrotter
Poland , Ohio
Corrosion
2019 GT
Checked batteries 3ish weeks ago. Don't recall seeing this. My batteries have been floating at 13.5, steady. Yesterday and today holding at 14.1, which caused me to check today. All fluids are good.
I'm a 50 amp currently on a 30. I am full- time with shore power. Batteries are in 'use' not 'store'
What could have caused this? What should I do?Click image for larger version
ID:	359036Click image for larger version
ID:	359037Click image for larger version
ID:	359038Click image for larger version
streamvizsla is offline   Reply With Quote
Old 01-12-2020, 07:25 PM   #2
Overkill Specialist
GMFL's Avatar
2014 23' International
Dadeville , Alabama
Battery give off corrosive gas while charging. You can spray the corrosion with Corrosion X to prevent further problems. But until you get rid of those wet cell batteries it’s just the way it’s going to be.
Old 01-12-2020, 07:50 PM   #3
Poland , Ohio
I understand. Thanks. One expense at a time.
Originally Posted by GMFL View Post
Battery give off corrosive gas while charging. You can spray the corrosion with Corrosion X to prevent further problems. But until you get rid of those wet cell batteries itís just the way itís going to be.
Old 01-12-2020, 07:54 PM   #4
Overkill Specialist
GMFL's Avatar
Dadeville , Alabama
Yep. I get it. The 27 Globetrotters are our current favorite. Corrosion X will solver your problem and prevent further issues.
Old 01-12-2020, 08:08 PM   #5
2018 25' International
Slidell , Louisiana
In addition to the spray on corrosion inhibitor, you can significantly reduce the problem by not slightly "overcharging". Turn off the AS provided converter/charger for at most a week at a time then charge them for a day or two and so on. The batteries off gas significantly more when fully charged and still receiving even a small excess current.
Since you indicated you don't want to make any significant investment, AGM batteries are off the list as is a "smarter" charger.
Brian
Old 01-12-2020, 09:03 PM   #6
Poland , Ohio
I wouldn't mind the upgrade, just one big expense at a time.
Old 01-12-2020, 09:05 PM   #7
Poland , Ohio
Thanks. I love my 27. A bit spendy, but I'm happy I did it.
Should I use Corrosion X on brand new trailer to prevent corrosion ILOVESALLY General Repair Forum 31 06-25-2016 01:06 PM
Stainless steel corrosion Dave-O Stoves, Ovens & Microwaves 21 04-05-2014 07:30 PM
ACF-50 Corrosion Inhibitor - Anyone used it? Bob Thompson Clearcoat, Exterior Paint & Trim 3 07-09-2004 07:40 PM
interior wall corrosion? 60traveler Interior Restoration Forum 12 08-11-2003 01:42 PM
corrosion under lites Chas Ribs, Skins & Rivets 4 05-18-2003 09:57 AM
