Old 03-19-2009, 07:01 PM   #1
FLYNCLD's Avatar
1962 22' Flying Cloud
Bend , Oregon
Correct size fuse for 12V circuits
I am installing a new power distribution panel in my 62' Flying Cloud. As there was no panel there before, and it appears all the 12v loads were essentially on one circuit, I will be dividing up the load into multiple circuits. My question is, is there a simple way to determine what size fuse you should use for each circuit. I am using 12G wire and it is my understanding that the fuse is there to protect the wire, not the devices, but there must be some correlation between the load/wire/fuse? Any help out there for use non-rocket scientists?
Thanks!
FLYNCLD
FLYNCLD is offline   Reply With Quote
Old 03-19-2009, 07:25 PM   #2
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
Depending on how many wires you need to fuse and how many users are on the circuit, I would start with a 15 or 20A fuse for a 12G wire. Much also depends on the wire length.
You should use much heavier wire from the battery or converter to the fuse panel, though, like a 4g battery cable.
Uwe
www.area63productions.com
Old 03-19-2009, 07:36 PM   #3
HowieE's Avatar
Princeton , New Jersey
Images: 12
#12 automotive wire is generally fused at 20 amps. # 14 wire at 15 amps.
Just make sure you fuse for the SMALLEST wire size in the circuit. Generally the factor would use the same size wire throughout a circuit but if anyone else added something they may have down sized that wire. Just check to be safe.
2004 Excursion 4x4
Old 03-19-2009, 08:47 PM   #4
FLYNCLD's Avatar
Bend , Oregon
That pretty well confirms what I have been thinking. As always, thanks to the members. The Forum ROCKS!!
FLYNCLD
Old 03-19-2009, 09:30 PM   #5
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
On early 70s the main power fuses connecting the converter and battery to the fuse panel were 40 amps. There were 4 other 20 amp circuits for the operational trailer circuits.
Old 03-20-2009, 07:15 AM   #6
87MH's Avatar
1978 31' Sovereign
Images: 292
Originally Posted by FLYNCLD View Post
... I will be dividing up the load into multiple circuits...there must be some correlation between the load/wire/fuse? Any help out there for use non-rocket scientists?
A fairly decent footage/gauge/amperage spreadsheet can be found here:
Voltage drop, distcance and wire guage
Use stranded copper hands down - the finer the strands the easier it will be to work with - solder all of the end connections if you can.
Don't scrimp on the wire gauge - the difference in the price of wire just does not justify cutting any corners - when the trailer is finished you will be glad that you "overwired".
Grounding is always a problem on older trailers - best to strap to both the frame AND the shell - better yet - run grounding wires from a central ground buss to each end user of the 12 volt system.
Read my signature line - do it right the first time....
Dennis
WBCCI # 1113
AirForums #1737
Trailer '78 31' Sovereign
Texas Airstream Harbor, Inc.
Old 04-23-2009, 05:13 PM   #7
Shiny metal's Avatar
2008 25' Safari SS SE
Livermore , California
I have a used 06 Safari and have no reference material. I would like to pick up some spare fuses. I would also prefer that I not remove the existing fuses from the fuse panel to use as an example. Can anyone tell me the length and amprege of the fuses I need to keep on hand. Thanking you in advance.
Shiny metal is offline   Reply With Quote
Old 04-23-2009, 05:39 PM   #8
HowieE's Avatar
Images: 12
Have you taken a look? I think they are circuit breakers not fuses.
2004 Excursion 4x4
12v
Correct size bolts for floor? Lothlorian Repairing/Replacing Floor &/or Frame 16 12-09-2012 05:44 PM
Fuse/12V Distribution Panel Mike S Batteries, Univolts, Converters & Inverters 5 11-13-2008 10:05 AM
What is the correct bearing size for a 1962 toastie Axles 16 11-02-2006 10:49 PM
12v fuse panel location? coldduc All Argosy Trailers 5 05-26-2004 06:15 PM
12V circuits dmadam Electrical - Systems, Generators, Batteries & Solar 7 04-07-2004 03:03 PM
