Old 07-24-2010, 12:36 PM   #1
1972 25' Tradewind
fsm , Arkansas
converter which one
I went to the Best Converter web site as suggested by Mexray. There are two converters, a 45amp and a 55amp, which one do I need. Also do I need a volt minder?
Robert
marley45 is offline   Reply With Quote
Old 07-24-2010, 03:18 PM   #2
LEV ZEPPELIN
crazylev's Avatar
2004 19' International CCD
Chicago , Illinois
Marley45,
I replaced our converter recently with a 55 amp converter kit from BC.
If I were you, I'd speak directly with (Randy?) at BC. The thing you need to consider is the original wiring gauge going to the converter, and going from the converter to your battery(s).
As far as a volt minder, I just have a voltage gauge plugged into one of our outlets so that I can keep an eye on voltage fluctuations, which actually fried my old converter!!!
Either way discuss your set-up. I found him most helpful in making my decision.
Jonathan
Sometimes I wish I were living in the stone age. Then I would know I'm the smartest person in the world.
crazylev is offline   Reply With Quote
Old 07-24-2010, 03:35 PM   #3
Mexray's Avatar
1978 28' Ambassador
Morada , California
I'm with Jonathan - Randy @ Best is the one to talk too - he steered me in the right direction when I replaced the old Univolt...
I recently added the Voltminder that they sell - it has an adjustable low voltage alarm that you can set to warn you when your battery charge level (voltage) is becoming low, so you can 'shut er' down' or go out and fire up the trusty red Honda Genny...
I opted for the 45 amp converter/charger, as we had only the two batteries...I've since added another battery, and now wish I'd gone with the 55 amp unit - However, the 45 amp unit seems up to the job of recharging our batteries in reasonable time when we're out in the boonies...
We've gone to all LED lights in our AS, inside and out, so the 'lighting' load isn't all that bad, and we're really only recharging the batteries for the use of the Sat TV or DVD at night, the fantastic fans when it's warm, and the water pump upon occasion...
I've found a long time ago, that it's best to fire up the Genny for a short period EVERY day when you're off the grid, to insure the batteries don't get to low - it you let em' go too long and get discharged completely, you'll find you need hours and hours to get em' back up to snuff...a little charge a day is best...
Enjoy...
Ray
Ray & Pat; Morada, CA
Old 07-24-2010, 05:41 PM   #4
68 TWind's Avatar
1968 24' Tradewind
Oxford, , Mississippi
I would suggest speaking with Randy at Best Converters. At his suggestion I bought the 55 amp, Iota. You have a couple of choices on monitoring the condition of your batteries. The cheapest is a volt meter, Randy has a good one. The other is a battery monitor, with will actually read the amps. These require installation of a special device, a shunt, in the line and they are really expensive, but if you want the best. I would also highly recommend a book that Randy sells titles "Managing 12 Volts", by Harold Barre. Every boat or RV owner needs it in their library. It is the most complete source of info on batteries and everything 12 volt that you will find.
Converter fuse blowing (new converter) wannaroam Batteries, Univolts, Converters & Inverters 28 07-06-2015 02:39 PM
110 and the converter Cstar Batteries, Univolts, Converters & Inverters 8 10-02-2010 11:07 PM
no converter hum ricochet Batteries, Univolts, Converters & Inverters 4 07-14-2008 11:10 AM
What is the best converter? jdalrymple Batteries, Univolts, Converters & Inverters 2 03-19-2008 01:42 PM
tv converter.. safari05-25 Audio, Video & TV 0 11-27-2006 07:10 PM
