Old 09-05-2016, 09:57 PM   #1
2011 28' Flying Cloud
Orillia , Ontario
Question converter upsize
Hello everyone
Can you up size to a 60 amp from 55 amp
I want to replace my converter out of my parallax 7355
They have up grade for this but thought about PG with charge wizzard
Rust is offline   Reply With Quote
Old 09-05-2016, 10:00 PM   #2
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
No reason not to.
Old 09-05-2016, 10:08 PM   #3
1979 23' Safari
Wayland , New York
5 amps difference isn't very likely to cause any problems. You'll hardly ever see a converter cranking out their rated output anyways. They will supply your 12v load which usually isn't really that much steady state amperage draw. Plus putting amperage/charge into a battery is not linear so you generally aren't pushing a ton of amps that way either.
Old 09-06-2016, 03:01 AM   #4
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
Talk with Randy at Best Converters. I just bought the PD upgrade kit (for the 55 replacement) and the instructions warn not to go higher than current amps due to overheating wiring. I'm no expert so would recommend talking with Randy or perhaps Lewster will chime in.
SteveSueMac is online now   Reply With Quote
Old 09-06-2016, 07:28 AM   #5
New Borockton , Alabama
Images: 21
Should be no problem.
Randy...Converters, Inverters, Trimetric, Surge Protectors, Zamp Solar, AGM Batteries
www.bestconverter.com
Old 09-06-2016, 08:01 AM   #6
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
Would this put additional load on a generator or other power supply, just to run the converter?
Doug and Cheryl
Old 09-06-2016, 08:18 AM   #7
Images: 21
Not an appreciable difference but it does take a little more power to "make" 60 amps than it does 55
Old 09-06-2016, 10:30 AM   #8
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
The converter would rarely if ever require the full 60 amps. The full load of 60 amps would be 720 watts. The current (amp) requirement of the converter on a generator or shore power is dependent on it's load requirement (ie battery charging, lights etc) plus any losses in the conversion process. 5 amps is 60 watts. Not a big deal in the scheme of things.
Old 09-07-2016, 02:06 PM   #9
1979 23' Safari
Wayland , New York
Keep in mind there are 2 different currents. The 12vdc side and 120vac side. Essentially 10-1 conversion so 5amps 12vdc will require only .5 amps 120vac more input on that side.
There is some conversion loss but not highly significant.
Old 09-07-2016, 08:12 PM   #10
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
.5 amps @ 120 volts is still 60 watts. Not a significant change in the load.
Converter fuse blowing (new converter) wannaroam Batteries, Univolts, Converters & Inverters 28 07-06-2015 02:39 PM
Univolt 45 amp converter to a 30 amp converter scooterbug76 Batteries, Univolts, Converters & Inverters 15 02-24-2013 02:59 PM
Converter relocation FrankR Batteries, Univolts, Converters & Inverters 0 07-31-2002 08:30 AM
Converter box floor mount FrankR Electrical - Systems, Generators, Batteries & Solar 0 03-27-2002 10:34 PM
Converter box for into floor mount FrankR Electrical - Systems, Generators, Batteries & Solar 0 03-15-2002 09:49 PM
