11-12-2012, 09:28 AM
1992 25' Excella
Grants Pass
, Oregon
Converter upgrade suggestions? ('92 25' Excella)
The original 50-amp converter in our 1992, 25' Excella is very loud. I'd like to replace it with a quiet, high-quality unit. Any suggestions about the units available or the installation process would be greatly appreciated.
11-12-2012, 09:36 AM
retired USA/USAF
2001 30' Excella
Somerset
, New Jersey
I did it 2x now on two different trailers. First was the IOTA 55w, 3stage. I was pleased with it got it and the advice from Best Convertors. Second was a different one also from Best Convertors. I'm happy with that one also, just a different one. Google them or find them here on this forum somewhere. They will steer you right. Not too expensive and an easy DIY job.
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
11-12-2012, 09:56 AM
2019 27' Flying Cloud
Albuquerque
, New Mexico
Iota DLS-55
I have purchased and installed converters on three Airstreams.
The Iota DLS-55 is the best one yet.
Quiet, efficient, easy to install; it has a very smart charger that operates equally well with shore power and generator power.
Hope this helps.
Ken L 2019 Flying Cloud 27FB
2020 GMC Sierra 1500 Crew Cab 6.2L Max Tow Four Corners Unit WBCCI #5783
11-12-2012, 10:19 AM
1986 32' Excella
Canton
, Georgia
Love our quiet, reliable intellipower! We have an 89 excella.
11-12-2012, 11:05 AM
Oswego
I have the Iota DLS 55 w/IQ4 and am very pleased after 2 years. Best Converter.com gives great advice. Call and talk to Randy, he may have new updated product info.
-Rich-
11-12-2012, 11:10 AM
Albuquerque
, New Mexico
These Are Good Too...
I have installed and used these in two Airstreams. They are good too.
Back to the Iota DLS-55, dzf0g is correct to mention "with IQ-4."
The IQ-4 provides the smarter charging. I don't know if they can be purchased without IQ-4, but it would be a serious oversight.
11-12-2012, 11:16 AM
Oswego
They are available with IQ4 internal.....OR a base DLS-55 w/o IQ4 and an external IQ4 module can be added....SOOOOOOO you need to be aware that you do want IQ4, IMO.
-Rich-
11-24-2012, 11:51 AM
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction
Why would a user not select one of the larger models made by Iota? Bigger units could charge batteries quicker?
11-24-2012, 09:00 PM
2003 25' Safari
Riverside
If using the origional wiring a larger convertor could put out more than the wiring can safely handle
11-24-2012, 10:06 PM
1974 Argosy 20
Kooskia
, Idaho
Batteries can only accept a certain charge rate and even though a converter/charger has a larger amp rating, the battery (s) may not be able to use it, and in fact there will be any advantage from a larger converter/charger. BTW, even the charge a battery can take will taper off rapidly as it charges.
I find a 45 to 60 amp converter/charger works well for most AS products.
11-26-2012, 08:09 AM
2014 31' Classic
Apache Junction
Talked with folks at bestconverter.com today and they stated they have sold very few Iota converter units over the last two years. They are supporting the Power Max Boondocker four stage units with 3 year warranty. They also recommended surge protection on the system.
They said their unit is plug and play with the OEM unit, and the model most appropriate would be the 60 amp model that replaced the 55 amp model.
Anyone have experience with this brand and model?
11-26-2012, 10:19 AM
1993 34' Excella
York
, South Carolina
I need to replace mine also, the hum has gotten steadily louder.
John
WBCCI #268 Palmetto State Airstream Club 22
Region 3 Past President....come with us, you will like it.
Go often to the house of a friend, for weeds choke the unused path........Emerson
Are you kind?..... Uncle John's Band
11-28-2012, 09:37 PM
2014 31' Classic
Apache Junction
Ended up ordering the Ultra III upgrade kit from Best Converter for the OEM Parallax 7355 converter to make it a triple stage charger and all DC circuits will be filtered and have clean power. Once installed into the original enclosure, the original look of the enclosure will be the same.
I also ordered the Trimetric current flow measuring device and the portable 30 Amp surge protractor.
11-28-2012, 10:02 PM
2012 28' International
Olympia
I'm probably going to go with the Boondocker. Randy said it would only require some minor mods to make it fit in the 7355 enclosure.
I'd like to do the Trimetric monitor as well. Where do you plan to mount it?
Dave
01-08-2013, 06:49 AM
1975 27' Overlander
Landenberg
, Pennsylvania
Dave
Did you go with the Boondocker I am trying to decide what converter to get for my trailer. so I would love to know how you made out?
01-08-2013, 07:09 AM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
Hope this helps.
Can only speak to what I have experience with...
P-lax...battery burner.
Xantrex replacement, failed out-of-the-box.
IOTA 55a DLS IQ4 has been an excellant choice for us.
08-02-2013, 07:21 AM
2013 27' FB Classic
Clermont
I need a new convertor - replying to subscribe to this thread.
Tom & Lori
2013 27 FB Classic Limited
2019 Ford F250 King Ranch 6.7L Diesel
WBCCI 03288 TAC PA-17
08-02-2013, 07:48 AM
Figment of My Imagination
2012 Interstate Coach
From All Over
, More Than Anywhere Else
You don't have to reply to subscribe to a thread. If you're reading a thread you want to subscribe to, just look for the "Thread Tools" pull-down menu right above the topmost post, and select "Subscribe to Thread."
08-02-2013, 09:19 AM
Olympia
I did get the Boondocker. This one.
55 Amp 4-Stage Main Board Replacement
The install wasn't too tough although I got to install it twice. I took the old Parallax out by removing the screws securing the box and pulling it out. Used 3M double side tape to secure the new unit to the floor. No big deal, right? But when I went to install the door on the front and crack a beer I found that the door is secured to the enclosure that I had removed with the P-lax converter. So I got to take the Boondocker back out. Then I had to get the P-lax converter out of it's enclosure box by drilling out the welds and using a little brute force, destroying the old converter. Then I remounted the new unit in the box and reinstalled. Now I have expertise I hope I never have to use again.
I checked charge voltages and they were right where I wanted them. I haven't had the trailer out yet to really check it out, but I'm pretty confident that Randy at BestConverter.com didn't steer me wrong.
Dave
2014 Ram 2500 CTD
Pro Pride
Centramatics
08-02-2013, 01:45 PM
1999 34' Excella
Hillsboro
Here..
Be careful about tools,,,,close proximity to rivets on Converter can make impressive sparks
Peace and Blessings..
Channing
WBCCI# 30676
