08-02-2013, 03:40 PM
#21
2013 27' FB Classic
Clermont
So I am having high voyage problems on my new 27 FB Classic. Getting readings of 16.2 - 20VDC
I dropped the trailer off at the dealer today and while discussing the problem, the technician indicated that the problem was most likely the "lower end" of the converter.
I inquired if I could replace the converter with a different make. The technician told me that we had to stick with the original converter because the entire 110v / 12 v would have to be rewired and new breaker panels installed. Our layout has the breakers / convertor beneath the pantry.
Any comments or recommendations?
Tom & Lori
2013 27 FB Classic Limited
2019 Ford F250 King Ranch 6.7L Diesel
WBCCI 03288 TAC PA-17
08-02-2013, 03:45 PM
#22
2012 25' FB International
Trent Woods
, North Carolina
Warranty?
This should be warranty work, why pay a penny for anything? Let them replace the converter with the same. It is not the best available but it is more than adequate.
Larry
08-02-2013, 03:54 PM
#23
2012 28' International
Olympia
Does yours look like this?
If so your tech doesn't know what he's talking about. I just installed a new converter. I used the same AC and DC panels. It involved 5 wires. 2 AC 2 DC and a ground. I now have a 4 stage charger that won't fry my batteries like the stock one.
Talk to Randy.
BestConverter - Converters, Inverters, Electrical Supplies, Electronics
Dave
2014 Ram 2500 CTD
Pro Pride
Centramatics
08-02-2013, 04:37 PM
#24
2013 27' FB Classic
Clermont
Talk to Randy.
It does look similar to this. I have 50 amp service. Does this matter?
Tom & Lori
08-02-2013, 04:42 PM
#25
Olympia
Nope.
Dave
2014 Ram 2500 CTD
Pro Pride
Centramatics
08-02-2013, 04:43 PM
#26
Alamo Heights
Talk to Randy.
Dave has it exactly right IMO. Several forums members have posted about this same upgrade recently, and probably more have done it than have posted about it. The dealer doesn't want to hassle with a non-factory part, but they either aren't being honest with you about it or they're just unaware of the upgrade converter that fits into the stock power center.
If you don't want to fight about replacing the Parallax with a better converter right now (since they're going to push to use the "factory" part for warranty work) at least make a note of the information so you can upgrade it when it dies or boils batteries after the warranty.
— David
08-02-2013, 05:36 PM
#27
Olympia
In the tech's defense, it isn't as simple as a direct swap out. It requires a little (very little) customization.
Dave
2014 Ram 2500 CTD
Pro Pride
Centramatics
08-04-2013, 06:57 PM
#28
2013 27' FB Classic
Clermont
What replacement brand / model would you recommend? I think I have a 55 or 60 amp convertor. I have AGM 27 batteries.
Tom & Lori
08-04-2013, 08:18 PM
#29
Alamo Heights
I believe that the upgrade converter for modern "power center" installations is this one from BestConverter.
I recommend you call BestConverter and discuss it with them to make sure before you go throwing money around, I haven't personally dealt with this, my converters are free-standing deck mount models.
— David
08-04-2013, 09:09 PM
#30
Olympia
+1 on what DKB said. Talk to Randy at Best Converters.
Dave
2014 Ram 2500 CTD
Pro Pride
Centramatics
08-06-2013, 04:17 PM
#31
Trent Woods
, North Carolina
Ultra III
I just installed the Ultra III upgrade from BestConverter for peace of mind. It is a simple install but it does take longer than they suggest as getting everything hooked up while down on the floor is a bit of a physical challenge. Nevertheless, no modifications are required so it is a well thought out upgrade.
Larry
08-06-2013, 05:14 PM
#32
2013 27' FB Classic
Clermont
Larry
Do you have any Photos?
Tom & Lori
08-06-2013, 05:22 PM
#33
Trent Woods
, North Carolina
Bestconverter.com has good photos on their website so I did not take any.
Larry
08-06-2013, 06:49 PM
#34
2013 27' FB Classic
Clermont
Larry
Is your convertor mounted under the breaker panel in the open or enclosed?
Tom & Lori
08-07-2013, 03:34 AM
#35
Trent Woods
, North Carolina
The fuse board and the lower portion of the converter are replaced, then the existing front panel is reattached. so it looks just like what was there, but the guts are new.
Larry
08-07-2013, 05:56 AM
#36
1995 30' Excella
Bowie
, Maryland
You can also put a 45 or 60 amp PD92xx converter in where the old "guts" used to be - this is what I did on my B190, and it worked perfectly. There are lots of options; as you said BestConveter.com will help figure it out.
1995 Airstream Classic 30' Excella 1000
2014 Ram 2500 Crew Cab with Cummins 6.7L Diesel
Sold but not forgotten: 1991 Airstream B190
Sold: 2006 F-250 6.0L Powerstroke Supercab
