Old 03-08-2016, 04:24 AM   #1
2016 25' Flying Cloud
Celebration , Florida
converter upgrade
want to upgrade to 3 stage multi converter. I have been told I have a Parallax 7300 5355B converter. Looking at Progressive Dynamics 4600V.
Need to know if this is the correct upgrade. The instructions that came with this PD4600V does not list Parallax 7300 as a compatible unit. If this is the correct upgrade is there any other pieces needed?
Just thought someone out there would have some input. thanks so much.
trigal is offline   Reply With Quote
Old 03-08-2016, 04:38 AM   #2
GLCMRANGER - Sue
2016 25' International
Littlestown , Pennsylvania
Randy from Best Converter recommended the PD 4655 upgrade kit when I inquired about my (soon to be delivered) 2016 25A Signature. Not sure about the PD 4600V. I doubt it would be a plug-n-play replacement, in that, you'd have to take out the panel with all the breakers. Also, it's a Parallax meaning P.O.S. from China.
glcmranger is offline   Reply With Quote
Old 03-08-2016, 05:48 AM   #3
thanks glcmranger, the unit is a PD 4655V the series is PD 4600. sorry for the confusion.
Old 03-08-2016, 06:05 AM   #4
SeaLevel's Avatar
Jupiter , Florida
I installed the PD4655 a little over a week ago in my 2016 25' FC. It was an easy swap, and it worked great on our first outing last weekend. I purchased it through Amazon, just because that's where I got the best price.
SeaLevel is online now   Reply With Quote
Old 03-08-2016, 11:26 AM   #5
Perfect, thanks for the update. Looking forward to the upgrade,
Old 03-08-2016, 12:49 PM   #6
Parallax 8355 converter
any body upgrade this 8355 converter to 3 stage converter?
Old 03-08-2016, 12:51 PM   #7
SeaLevel's Avatar
Jupiter , Florida
Yes. As stated above, I replaced it in my 2016 25" FC. No problems. Easy swap, and well worth it.
Old 05-10-2016, 06:30 PM   #8
honi soit qui mal y pense
Robere's Avatar
2015 23' FB Flying Cloud
Bend , Oregon
Battery question:
What if I were to upgrade the converter in my 2015 23' FC FB to a Progressive Dynamics PD 4655 and change out the 12v Interstate SRM24 Batteries to 6v Interstate GCZECL Batteries? Would that be a good long term cost effective decision for someone who likes to boondock? I have a portable 160 watt Zamp solar setup, no generator and generally frequent sunny locations.
Robere is offline   Reply With Quote
Old 05-10-2016, 06:43 PM   #9
2015 30' Classic
Pleasanton , California
If you already have a solar controller with a three-stage battery charger and you don't plan on using a generator, save your money. There are a few folks on the forum who upgraded to solar but have kept their original converter. Just make sure the Use/Store switch is in the "Store" position when connected to shore power, otherwise your converter will try to charge your batteries.
Now adding battery capacity is always a good idea if you do a lot of boondocking.
Al, K6IV
2015 30' Classic, "Chez Nu"
2014 RAM 2500 w/Cummins Diesel
ProPride Hitch, 400 W Solar
alano is offline   Reply With Quote
Old 05-10-2016, 07:05 PM   #10
Caffeinated's Avatar
2015 27' Flying Cloud
Portland , Oregon
Trigal, I did this upgrade last fall, and I think I made every rookie mistake that one could. If you decide to do this, take a look at my thread and maybe save yourself a few trips to the store for the right tools.
http://www.airforums.com/forums/f449...ml#post1698737
Mike
Caffeinated is offline   Reply With Quote
12V converter/battery/monitor upgrade dznf0g Batteries, Univolts, Converters & Inverters 35 01-31-2016 07:49 PM
Upgrade converter? Breadbug Batteries, Univolts, Converters & Inverters 5 01-15-2011 02:08 PM
replace and upgrade converter fuse block nikiarntz113 Batteries, Univolts, Converters & Inverters 3 11-28-2010 09:24 AM
Converter Upgrade nickmeloy Batteries, Univolts, Converters & Inverters 2 10-11-2010 03:50 PM
Upgrade converter in '05 Classic 31? bandboss Batteries, Univolts, Converters & Inverters 3 03-01-2006 05:58 AM
