Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar > Batteries, Univolts, Converters & Inverters
Old 11-12-2007, 06:18 PM   #1
nairnchyz
Profile:  Roblin , MB.
Converter Swap
Hello,
Could someone give advice as to whether a Parallax 7300 Series Converter 55 AMP from a later model A/S would install and work in a '74 Sovereign?
nairnchyz is offline   Reply With Quote
Old 11-12-2007, 06:50 PM   #2
Zeppelinium
Zeppelinium's Avatar
Profile:  1970 18' Caravel
1977 23' Safari
1975 31' Sovereign
Palmer Lake , Colorado
absolutely no problem. The new converters all put out well regulated 12 Volts (really more like 13.4, which is what the battery likes, unless you're in a short anti-sulfate mode, when the voltage is around 14.4). It doesn't matter what the current capability is, as long as it's enough to carry your load. A converter with more current capability doesn't try to stuff it into the battery.
The only problem I've encountered is that the old Univolts had a fuse panel, so I've had to buy a fuse block when I put the new converter in. In some cases you could detach the Univolt fuse panel and remount it (carefully and with the proper enclosure to prevent inadvertent shorts, like from the wrench that's bouncing around in the vicinity of the panel). A modern fuse block for those square automotive fuses is going to run $30+.
Zep
Current 6-word memoir: Vintage Airstreams: Four are not enough.
www.mindseyephoto.com www.airstreamdoctor.com
Old 11-12-2007, 10:58 PM   #3
healthchic
healthchic's Avatar
Profile:  2004 19' International CCD
haines city , Florida
talk to Randy at bestconverter.com and he will take care u. he is all so on the forum.
the other half of the healthchic, Bill
healthchic is offline   Reply With Quote
Old 11-16-2007, 10:07 AM   #4
68 Overlander
Commercial Vendor
Profile:  Boise , Idaho
Images: 21
Bob,
I don't think you want to do that, but it can be done. The 7300 is a power center. It has an integrated AC/DC distribution panel on the top and a converter section on the bottom. This would require routing all of your AC and DC wires to this new unit. What I would recommend is a deck mount stand alone converter/charger to replace the Univolt. If your Univolt has the DC fuse panel integrated on the end of it, you can split the case and salvage that fuse board, or purchase a new board. The only advantage of a new board is a cleaner install and the ability to use modern blade style auto fuses.
Which ever route you decide, I'm not a fan of the 7300 anyway because it does not have multi-stage charging. The only Parallax unit I would consider is the 4455TC Paramode. It is a deck mount with temperature compensation and very popular. Others to consider are the Xantrex, Inteli-power and WFCO.
Old 11-16-2007, 10:36 AM   #5
nairnchyz
Converter Swap
Thanks Randy
As we are first time owners (October 2007) of an '74 Sovereign A/S it probably will take awhile to digest the information you have provided and check out further information in the links you have posted.
We've just started into the deep freeze weather of Manitoba so we do have approximately 6 months before the converter problem needs to be corrected!!
It is just so reassuring to know that there are so many forum members who are so willing to get us first timers up and running. No doubt some of us would make costly mistakes if it wasn't for all the kind advice.
Thanks to all,
P-30 Engine swap Bfrank Mechanics Corner - Engines, Transmission & More... 10 06-21-2007 07:00 AM
2004 Safari Converter swap flsafari Electrical - Systems, Generators, Batteries & Solar 13 10-31-2005 08:47 AM
Dinette swap Chaplain Kent General Motorhome Topics 20 07-10-2005 07:01 PM
tranny swap fullquvr Mechanics Corner - Engines, Transmission & More... 1 05-28-2004 07:12 AM
swap rock guards bill benton Parts Archive 4 03-25-2004 07:21 PM
Cooking Forum - Sailing Forum - Early Retirement
Airstream Trailer Forum - Aquarium & Reef Forum
Royal Forum - Book and Reader Forum - Yoga Forum
Volkswagen Touareg Forum - Jeep Wrangler Forum
Whitewater Kayaking & Rafting Forum - Yoga Forum
U2 Forums
