Old 08-05-2009, 05:47 AM   #1
2005 22' International CCD
Woodland Park , Colorado
Converter remains on bulk charging
My converter will not switch off bulk charge mode. It is a WFCO 9845 converter (Parallax upgrade kit purchased from Randy at BestConverter.com about 2 years ago).
Everytime the converter is on and charging batteries it is running at 14.4 volts and the fan is going full time. The batteries are completely full.
I have switched it on and off a number of times, unplugged it and plugged it back in and it still does the same thing. A few times it has gone into absorption stage charging (13.6 volts) for a period of time but then later will switch back to 14.4v.
I did have it disconnected recently to do a floor renovation. However, I am sure I connected everything back correctly and it was working after the floor mod. It works fine running the 12v electrical in the trailer when the batteries are disconnected; as soon as I connect the batteries it jumps back to 14.4 and stays there.
My guess is the microprocessor inside the converter is shot. I have a call in to Randy at BestConverter to see what his thoughts are but wanted to see if anyone else has had a similar problem.
Thanks in advance for any insight anyone may have. jon
JK3500 is offline   Reply With Quote
Old 08-05-2009, 08:09 AM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
If you look at where te converter was made you will understand the problem. They are known for excessive noise from plate separation and short life.
Consider a Progressive converter with the Wizard Monitor.
2004 Excursion 4x4
Old 08-08-2009, 09:34 AM   #3
Yep. I think you're right. Tried a number of things, desconnecting, reconnecting, etc and it looks like the converter is shot.
Will look into a Progressive....
Thanks, jk
Old 08-08-2009, 09:44 AM   #4
tlavergne's Avatar
1978 28' Ambassador
Kenton , Ohio
In 2001 I replaced my univolt with a Progressive and Charge Wizard in my 1978 Ambassador. Never a problem...works flawlessly. I highly recommend one. Very easy install.
Tom
"Without music to decorate it, time is just a bunch of boring production deadlines or dates by which bills must be paid." -- Frank Zappa
tlavergne is offline   Reply With Quote
Converter fuse blowing (new converter) wannaroam Batteries, Univolts, Converters & Inverters 28 07-06-2015 02:39 PM
Charging in the 88 Ed Emerick Batteries, Univolts, Converters & Inverters 1 05-06-2009 07:53 PM
How to buy Truckbox Polish in bulk (gallon size) ronstory Cleaning, Stripping & Polishing 0 10-21-2008 10:31 AM
charging again ALANSD Mechanics Corner - Engines, Transmission & More... 9 09-29-2003 06:26 AM
Charging ALANSD Airstream Motorhome Forums 5 09-16-2003 01:12 PM
