Old 05-14-2015, 04:31 PM   #1
1964 19' Globetrotter
eagle , Idaho
converter recommendation for 64 globe trotter
looking to upgrade the converter in the airsteam as we re work everything
any recommendations?
i'm looking at this?
is 70 amps too much?
Amazon.com: Progressive Dynamics (PD9270V) 70 Amp Power Converter with Charge Wizard: Automotive
thanks
idahoair is offline   Reply With Quote
Old 07-06-2015, 03:01 PM   #2
1990 33' Land Yacht
Chance , Maryland
have a 1990 airstream landyacht with energenius eg3000 series the breaker with the white test button has blown, what do i do, and where do i get a new one?
bjkayla is offline   Reply With Quote
Old 07-06-2015, 04:55 PM   #3
1974 Argosy 20
Kooskia , Idaho
thanks
It is unnecessarily over capacity. A PD 9245 would be just fine. The main reason an oversized unit might not be best is if you are running it on a smaller generator like a Honda 1000 or even a Honda 2000. With the higher charge rate possible, the generator may overload.
More rated amps does not necessarily mean that the battery it is attached to can accept that higher current, so in general, no reason for it.
Contact Randy at Bestconverter.com for excellent advice. And they are in the Boise area too.
1963 Airstream Globe Trotter - Where Can I find these Parts Uncle_Phil 1960 - 1964 Globetrotter 12 03-27-2014 05:39 PM
1964 Globe Trotter :: 1964 Airstream Globe Trotter Wilcu Airstream Registry Discussions 1 03-11-2012 05:35 PM
Grey water tank for a 68 Globe Trotter Bryanhu Waste Systems, Tanks & Totes 5 06-26-2003 10:18 AM
Serial number of 1960s Globe Trotter ? What year is it ? oldvws Our Community 1 12-12-2002 09:25 PM
