Old 08-03-2010, 02:49 PM   #1
1963 16' Bambi
Philadelphia PA, and Takoma Park MD
Send a message via AIM to roadtrip07
Converter Question
I am restoring my 1963 Bambi, and I'm getting to rewiring the electrical system, and I have a few questions. I know I need a converter as part of the new system, but I'm not quite sure how it fits into the system. Does the shore power go into the converter, and then battery? Also, does the converter have bypass circuits to wire the 120 VAC directly to it? If someone could clarify how exactly these converters function in relation to the entire system, that would be much appreciated.
roadtrip07 is offline   Reply With Quote
Old 08-03-2010, 03:36 PM   #2
silverleeper's Avatar
1967 22' Safari
1960 Caravel
Edmonds , Washington
Images: 8
This is a quick answer. The converter get power from the 120VAC main fuse box. This might help too.
On Edit: This is a good post to read.http://www.airforums.com/forums/f37/...mps-26482.html
Lee
1973 F-250 4X4 390
1965 Chevy Suburban 454
AIR 6030
WBCCI 4258
TCT
silverleeper is offline   Reply With Quote
Old 08-03-2010, 05:25 PM   #3
68 TWind's Avatar
1968 24' Tradewind
Oxford, , Mississippi
Randy at Bestconverter.com has a book, "Managing 12 Volts" which is excellent. I recommend it for anyone with a RV or boat. In it you will find everything you need to fully understand the "how" of a trailer 12 volt system.
Bruce & Rachel
68 Trade Wind
2001 Toyota Tundra
Converter fuse blowing (new converter) wannaroam Batteries, Univolts, Converters & Inverters 28 07-06-2015 02:39 PM
What is the best converter? jdalrymple Batteries, Univolts, Converters & Inverters 2 03-19-2008 01:42 PM
tv converter.. safari05-25 Audio, Video & TV 0 11-27-2006 07:10 PM
Converter/Generator Question? Towster Generators & Solar Power 18 12-26-2003 08:12 AM
Why use a converter? PatCrusse Electrical - Systems, Generators, Batteries & Solar 2 11-27-2002 06:52 AM
