First are you sure the converter is cycling or is it just the fan on the converter you hear cycling?
Disconnect the batteries and check the voltage on them. Now hook up the converter and record the voltage, watch the voltmeter when you hear the converter cycle. If the converter is working the voltage should be about 13.8 while charging. If there is no increase when you hear the converter or if there is a small decrease I would say it is the fan cycling. This may be because of dirt in the converter.
2004 Excursion 4x4
