Old 04-20-2016, 11:10 AM   #1
rugjenkins's Avatar
1975 Argosy 28
Springville , Alabama
Converter or inverter?
I'm replacing all the electrical.
All my appliances will be electric- 120v.
Which would work in this case-converter or inverter?
Matt
rugjenkins is offline   Reply With Quote
Old 04-20-2016, 11:20 AM   #2
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
You will definitely need a converter to charge your batteries and power the 12 volt DC functions of your trailer.
Brian
SuEllyn & Brian McCabe
Old 04-20-2016, 11:22 AM   #3
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
Inverter.
I did the same thing, all of my trailer is 120 except for the water pump and the porch lights.
However, you will need a good charger to keep your inverter batteries in good shape.
I just installed a 45 amp smart charger this week after stumbling along with a ten amp dumb charger for a couple of years.
Superat stultitia.
Old 04-20-2016, 05:32 PM   #4
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
How much room do you have for batteries?
Do you plan to always have shore power ?
If so. You don't need an inverter. Only a converter for the 12 volt devices that remain.. ie water pump, furnace, lights. The converter will also charge the house battery(s).
Old 04-20-2016, 05:43 PM   #5
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Which one you need depends on what you are trying to do.
A converter changes shore power, ~120v AC to ~12v DC, to charge batteries or power 12v appliances.
An inverter changes ~12v DC stored in the battery (or provided by solar) to ~120v AC to power 120v AC appliances. You will need a substantial battery bank to power a few appliances.
add edit:
You must have a battery to operate the accidental disconnect emergency brake, so you must have some way to charge that battery. You will need the converter.
Old 04-20-2016, 09:53 PM   #6
rugjenkins's Avatar
1975 Argosy 28
We mostly camp with shore power 99% of the time. The battery or batteries will go under my bed in the rear.
Suggestions and advice needed. I want to hear what y'all have done on yours. So I can way it all out. Thank you at all who have replied- J Morgan, TG Twinkie, A W Warn and moose tags
Matt
Old 04-21-2016, 12:30 AM   #7
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
As I mentioned above, I have hardly any 12 volt anything.
I run household light fixtures and residential propane fired appliances, (electric refrigerator).
I run two 100 amp hour batteries that power an inverter that will run everything but the air conditioner.
I use two double throw double pole switches that allow me to control the input to the entire breaker panel.
I can select shore power, inverter, or generator with these two switches.
I use the inverter when traveling to run the refrigerator in the day and the lights at night. On a typical travel day my tow vehicle will run the fridge and recharge my batteries sufficient for an overnight stay to mid morning unless I need to run the furnace a LOT.
It isn't a setup that is ideal for a lot of boondocking without a generator, but for my use it works well. (My use is from shore power to shore power with a couple of travel days and nights in a Lowe's or Home Depot parking lot in between. I always carry a generator, but don't really use it unless it is real cold or hot outside.)
Superat stultitia.
Old 04-21-2016, 10:06 AM   #8
rugjenkins's Avatar
1975 Argosy 28
J Morgan, thank you for the details. I have looked at many of your posts on your electrical setup. The detailed info here really brings some understanding. If I have more questions on setup Id like to pm you.
Matt Jenkins
Matt
Old 04-21-2016, 02:16 PM   #9
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
Anytime!
Name:	ImageUploadedByAirstream Forums1461269724.368538.jpg
My "transfer switch"
Superat stultitia.
Old 04-21-2016, 02:52 PM   #10
rugjenkins's Avatar
1975 Argosy 28
Wow that looks great! The buttons look huge.
Matt
Old 04-21-2016, 04:13 PM   #11
aftermath's Avatar
Spokane , Washington
Matt,
I am still a little confused with your plan. Here is the way I see it.
Unless you change EVERYTHING to 110 you will need a converter. A good converter not only changes your 110 to 12 volts but it also charges your battery. Are you going to have a 110 v water pump? Are you changing out the fridge for an apartment style that runs on 110? An RV refrigerator has a board that runs on 12 v.
Now, if you are planning on doing a lot of boondocking you could use an inverter to run your 110 appliances from your batteries. You will need good batteries and perhaps even a solar charging system to help out. J Morgan is doing this I think.
You mentioned that you are almost always hooked up to shore power. If that is the case, I don't think you will have the need for an inverter. I carry a generator to power up the 110 appliances when I am not connected to shore power.
aftermath is offline   Reply With Quote
Old 04-21-2016, 05:08 PM   #12
2011 27 FB International
Vancouver , British Columbia
You could go with an inverter/charger such as a Magnum. If you're running all AC appliances, be sure to get a large enough inverter (and battery bank if planning any off grid even for a night). Probably should also go pure sine wave (more expensive).
mixedpuppy is offline   Reply With Quote
Old 04-21-2016, 05:23 PM   #13
rugjenkins's Avatar
1975 Argosy 28
Frig will be a residential unit.
Water heater will be a tankless.
Water pump 12v
Stove is gas
I'm still weighing all options. I originally leaned toward the converter! J Morgans setup intrigues me because it seems backwards.( not saying that it is, I'm just lacking in understanding) So I'm studying the layout. I do like that his tow vehicle runs his frig while in tow. I would like to install solar too and most systems use an inverter from what I can tell.
I've learned there is more than one way to skin a cat!
My biggest concern with the inverter setup is- I'm in the south and the a/c is not an option but a must!
Matt
Old 04-21-2016, 05:25 PM   #14
rugjenkins's Avatar
1975 Argosy 28
I do plan on traveling the country soon so they maybe nights I'm in transit in a lowes.
Matt
Parallel non inverter generator with inverter generator? mtbguy Generators & Solar Power 3 07-15-2015 01:48 PM
inverter or converter? slapshift Batteries, Univolts, Converters & Inverters 5 08-12-2008 12:56 PM
Alternatives to Factory Converter & Inverter shovelbum Batteries, Univolts, Converters & Inverters 17 04-04-2008 11:14 PM
Converter / Inverter? Phil Gobie Electrical - Systems, Generators, Batteries & Solar 2 12-10-2006 09:57 AM
where is the converter/inverter thing? jnanacaksus Electrical - Systems, Generators, Batteries & Solar 13 08-28-2005 10:10 AM
