Old 04-21-2016, 07:03 PM   #15
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
To run the A/C you will need either shore power or a generator no matter which way you go.
My thinking when I picked my direction was that:
A. Inverter technology has come a long way in the past 20 years.
B. Running a dual A/C D/C system is double the work
C. Residential appliance and fixtures are as a rule cheaper than RV/marine dedicated units.
The single down side in my opinion is that I give up about 10% of my battery capacity to inverter overhead.
I use a modified sine wave converter, two years now with no ill effects to any of my devices or appliances.
The switches on my transfer switch look like regular household light switches, albeit with three positions. (They don't show well in the dark photograph)
Superat stultitia.
Parallel non inverter generator with inverter generator? mtbguy Generators & Solar Power 3 07-15-2015 01:48 PM
inverter or converter? slapshift Batteries, Univolts, Converters & Inverters 5 08-12-2008 12:56 PM
Alternatives to Factory Converter & Inverter shovelbum Batteries, Univolts, Converters & Inverters 17 04-04-2008 11:14 PM
Converter / Inverter? Phil Gobie Electrical - Systems, Generators, Batteries & Solar 2 12-10-2006 09:57 AM
where is the converter/inverter thing? jnanacaksus Electrical - Systems, Generators, Batteries & Solar 13 08-28-2005 10:10 AM
