Old 09-10-2015, 06:50 PM   #1
KYAirstream's Avatar
Northeastern , Kentucky
Converter on GFCI
My converter is plugged into an outlet fed by an exterior GFCI. Is there a reason for the converter being protected by a GFCI, or did it just happen to be wired this way?
KYAirstream is offline   Reply With Quote
Old 09-10-2015, 07:08 PM   #2
2015 16' Sport
Portland , Oregon
GFCI's protect people from getting electrocuted. They don't protect the converter. Probably to make sure nobody gets zapped.
leedav is offline   Reply With Quote
Old 09-11-2015, 08:25 AM   #3
I understand the kitchen, bath, and outdoor outlet being on a GFCI.
Is there some reason/requirement that a converter be installed on a GFCI?
Old 09-11-2015, 09:37 AM   #4
2015 16' Sport
Portland , Oregon
converter converts AC to DC via a bridge diode circuit. that DC is relative to the ground potential of the feeding AC circuit. If that ground is disrupted, the DC ground could possibly be many volts above the potential of the earth. Touching your trailer at that time could cause a potentially painful or lethal ground fault.
Old 09-11-2015, 10:15 AM   #5
Thanks. Would the voltage of the DC ground be any higher than that of a regular AC circuit if the ground is disrupted?
Old 09-11-2015, 10:19 AM   #6
2015 16' Sport
Portland , Oregon
Not higher, more likely some percentage of the AC voltage, but enough that you'd not be happy :-), and AC gives you 120 chances a second to let go. DC gives you none
Old 09-11-2015, 10:40 AM   #7
Got it. Well, sort of. Your point being that DC can be much more dangerous without a solid ground, since it's harder to let go.
Old 09-11-2015, 10:51 AM   #8
2015 16' Sport
Portland , Oregon
either way.. GFCI is a good thing.
Old 09-11-2015, 11:57 AM   #9
Just didn't know if it was any more necessary for the converter than any other 110 circuit in the trailer (besides kitchen and bath).
My converter receptacle is fed by a GFCI on the outside of the trailer. Sometimes when plugging in a griddle, crockpot, etc to the outside GFCI we will trip it. Not a big deal, but got me thinking about running a dedicated line for the converter, but wasn't sure if it needed a GFCI. Since my converter isn't the most accessible to reset a GFCI receptacle, I may just go with a GFCI breaker instead.
My Trailer Trips the GFCI Circuit - Help? weiss1957 Electrical - Systems, Generators, Batteries & Solar 29 12-30-2008 09:46 PM
Gen. GFCI tripping Cochese Generators & Solar Power 1 08-13-2008 06:54 PM
gfci help oakie Lights - Interior & Exterior 2 06-07-2007 09:50 PM
Gfci achip Electrical - Systems, Generators, Batteries & Solar 4 07-22-2006 12:52 PM
Gfci jcf48 Electrical - Systems, Generators, Batteries & Solar 0 07-21-2006 12:00 PM
