Old 04-18-2015, 09:05 PM   #1
2015 22' FB Sport
Winter haven , Florida
Converter noisy
When the converter is noisy like there was fan coming out like a air, what is the problem? Is it something with the fuse?
ronaldee is offline   Reply With Quote
Old 04-18-2015, 09:10 PM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
If you are asking if the cooling fan should be running when the converter is under load, the answer is yes.
Old 04-19-2015, 04:43 AM   #3
2015 22' FB Sport
Is it normal then thanks
Old 04-19-2015, 04:54 AM   #4
sandlapper's Avatar
1993 34' Excella
York , South Carolina
The fan will come on to help cool the converter when it is working. Some fans/converters are noisier than others. But it is normal.
John
WBCCI #3892
Region 3 , 1st VP
Go often to the house of a friend, for weeds choke the unused path........Emerson
Never pick a fight with an old man. If he is too old to fight he will just kill you........a wise old man.
sandlapper is offline   Reply With Quote
Old 06-18-2015, 11:46 PM   #5
2015 25' Flying Cloud
Eugene , Oregon
Better Fan?
Is there a quieter replacement fat that I can buy for the inverter?
ltorgy is offline   Reply With Quote
Old 06-19-2015, 10:24 AM   #6
sandlapper's Avatar
1993 34' Excella
Check with Randy at Best Inverters.
John
WBCCI #3892
Region 3 , 1st VP
Old 06-19-2015, 11:29 AM   #7
tsunami's Avatar
2016 28' Flying Cloud
Brandenburg , Kentucky
Images: 20
Just replaced mine due to it being very noisy when the overhead lights were on and it really squealed when more load was added to it. I called Best and ordered a replacement. Did the swap-out myself and now, not a peep out of it. Also enhanced the battery monitoring for the AGM's to keep from over charging them. Good luck.
tsunami is offline   Reply With Quote
Old 06-19-2015, 11:10 PM   #8
Eugene , Oregon
I will check with Randy at Best. The fan I have in my inverter is darn noisy. Granted, it only comes on when it needs cooling, but it would be nice to have something quiet. Thanks again.
Old 07-06-2015, 02:59 PM   #9
1990 33' Land Yacht
Chance , Maryland
have a 1990 airstream landyacht with energenius eg3000 series the breaker with the white test button has blown, what do i do, and where do i get a new one?
bjkayla is offline   Reply With Quote
Should I be worried about a noisy converter? J5MM 2006 Safari SE 4 10-04-2011 06:12 PM
noisy refrigerator fan Turtle 1997 - 2004 Bambi 9 06-03-2004 04:45 PM
noisy water lines kooblekidz Airstream Motorhome Forums 1 08-03-2003 02:35 PM
Fantastic fans very noisy - wore out? ipso_facto Roof Vents, Skylights & Fans 5 07-17-2003 07:47 AM
Aquajet noisy? Why no more 3-way refrigs? Kistler Water Heaters, Filters & Pumps 5 11-24-2002 09:23 AM
