Old 12-20-2015, 02:04 PM   #1
1983 31' Excella
Everett , Washington
Converter Life?
Hello, I hope some one has an answer for me regarding converters, I have 2 batteries my 31' Excella How long is a converter average life ( mine is 17 years old) One of the batteries (only 5 months old) Deep Cycle, was way down on water and the other one was fine. But they are not holding a charge. the only draw is the clock. while in storage. I have 110 for about 2 hours per day. Your thoughts? Thanks and Merry Christmas to all
russelld is offline   Reply With Quote
Old 12-20-2015, 04:09 PM   #2
2015 30' Classic
Pleasanton , California
The first recommendation is to change out your converter to one that includes a 3-stage battery charger. It's not recommended to use a single-stage charger/converter for long periods with lead-acid deep cycle batteries and doing so will reduce the service life of the batteries.
The second recommendation is that once the batteries are fully charged, I'd measure the state of the batteries with a hydrometer (cost you $10-$20) and replace either of both batteries if the specific gravity measures low after a complete charge (don't forget to correct for temperature).
Al, K6IV
2015 30' Classic, "Chez Nu"
2014 RAM 2500 w/Cummins Diesel
ProPride Hitch, 400 W Solar
alano is offline   Reply With Quote
Old 12-20-2015, 05:42 PM   #3
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
Ditto with respect to installing a three stage charger. Also, consider AGM batteries next time. They are "maintenance free" and do not need to have water levels checked or water added.
Bob Martel
WBCCI# 5766
Old 12-20-2015, 06:32 PM   #4
dougandlori's Avatar
2004 28' Classic
Fresno , California
Changing the converter to a 3 or 4 stage modern unit is the first thing I do when I purchase a new to me Airstream. Talk to Randy at bestconverter.com
Doug & Lori
Fresno
2004 28' Classic
2007 Ram 2500
dougandlori is offline   Reply With Quote
Converter fuse blowing (new converter) wannaroam Batteries, Univolts, Converters & Inverters 28 07-06-2015 02:39 PM
Univolt 45 amp converter to a 30 amp converter scooterbug76 Batteries, Univolts, Converters & Inverters 15 02-24-2013 02:59 PM
Life's lessons FrankR Off Topic Forum 2 08-05-2002 08:36 AM
Trailer Life RV Campground Finder Pahaska Our Community 12 08-03-2002 08:45 AM
Trailer Life cover 83Excella Our Community 6 06-16-2002 10:14 AM
