Old 09-25-2011, 07:28 PM   #15
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
I was simply applying Occam's Razor. First inverter is overloaded, then shore power provided by generator is overloaded, 120v problems continue until breaker supplying converter AND bedroom outlets opens, returns when you close this breaker until apparently the converter slagged and opened the short before the breaker opened. The fact that a single breaker supplies the converter AND outlets that are hot when you're running off the inverter suggests that the inverter can supply power to the converter, which is inefficient.
— David
DKB_SATX is online now   Reply With Quote
Old 09-27-2011, 02:32 PM   #16
Islander
kingfisher24's Avatar
2005 28' International CCD
Deer Harbor , ORCAS ISLAND WA
to replace parallax 7300
can one replace this unit with the iota DLS-55
i Think???the parallax supplied as original equipment is a 30 am charger????
can it be replaced with a 55 amp converter/charger?
does one just replace the power unit and use the existing buss bars...breakers and fuses??????
Kingfisher24
and the Four P's(Paula, Phoenix and Peabody II and Pearl)…Peabody is here…..
2013 GMC sierra denali
WBCCI 2541
4CU
kingfisher24 is offline   Reply With Quote
Old 09-27-2011, 03:21 PM   #17
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
KF
If it's installed like this the replacement is a snap.
I used the DLS55 in our 03 Classic.
ID:	141133   Click image for larger version
PFC
"Tahawus"
but I’m the Husband, so we went to Cleveland. 😂
RLC
“It’s a crooked piece of time that we live in….”
John Prine
Old 10-11-2011, 05:41 AM   #18
Islander
Problem solved!!!!!!!!!!!
Thanks to the fine folks at Holiday, the albuquerque New Mexico airstream folks.
It was, as my uninformed self suspected, the demise of my Parallax 7355 converter.......
it just died,,,i guess....but with a new one on board all systems are go.......
Kingfisher24
WBCCI 2541
4CU
