Originally Posted by Doug C
92 Excella 25'
It sounds like one more reason to go with the 45-amp unit which will allow use of a lighter, smaller, less expensive generator. Am I missing something here? Any good reason to go up to a 55- or 60-amp unit to replace the original 50-amp Magnetek?? The trailer is stock and I don't plan to add a lot of electrical appliances to it.
Thanks for the good feedback.
Doug
Doug.
Instructions can be offered on "how to use".
Suggestions can be made as to "what to use".
Only you can decide and program your useage desires.
A 45 amp converter draws 540 watts.
A 55 amp converter draws 660 watts.
A 60 amp converter draws 720 watts.
Add an efficiency factor of about 25 percent to those numbers.
That's the power consumption only if the converter is operating at 100 percent, which they never do for more than a very few minutes.
That amount of power consumption is far less than a coffee pot or toaster.
When in doubt choosing a generator, don't under rate what you may do. Time will tell you that you forgot something. Then your stuck with a generator that's inadequate.
If you want to enjoy, plan accordingly, but always add a "safety" or reserve factor, especially when it comes to using electricty.
