Old 08-08-2009, 10:00 AM   #15
wannaroam's Avatar
1978 31' Excella 500
Harmony , Pennsylvania
Images: 36
The wall receptacle is a 3 prong, and other things plugged in there work normally.
We bought this converter 2 yrs and 6 weeks ago. We didn't get it installed until about a year and a half ago, and only began using the trailer last fall, as we were rebuilding almost everything. We never boondocked until last month and that was when we realized that the batteries weren't charging. Of course, it is now 6 weeks out of warranty as luck would have it. I suspect that this unit never worked - we noticed that with two new batteries the status lights never read higher than "good". After boondocking and losing all battery charge my husband manually charged the batteries up from the tv battery and finally it read as a full charge.
I am most disappointed in the person we bought this from. We called him several times over three days, and emailed him (per his request) and never got a reply by either method, all we could ever get was a recorded message when we called. Finally my husband got the Parallax company on the line and explained to them what was going on and they called the dealer, who called us right back. But with an attitude. And of course we were told it is out of warranty, period.
All of you know it takes a long time to get a unit refurbished and on the road. I just wish we would have realized that this wasn't working 6 weeks ago. We now appear to be stuck for a $225.
Does anyone else have any other ideas? If it is a bad ground could we/should we attempt to fix that ourselves? Or send it to the factory to see if it can be fixed?
wannaroam is offline   Reply With Quote
Old 08-08-2009, 10:20 AM   #16
1965 26' Overlander
Renton , Washington
you are positive that the 120 ac wiring is hooked up correctly at the converter? and the wires from the converter to the battery are hooked up correctly? can you post any pictures of these connections?
nate3172 is offline   Reply With Quote
Old 08-08-2009, 10:23 AM   #17
wannaroam's Avatar
Images: 36
I will try to see if I can get pix. Hubby took it down last week and boxed it up in the hopes that we would be able to send it back.
Old 08-08-2009, 12:16 PM   #18
richinny's Avatar
2011 34' Classic
i'd also verify that the polarity is correct at the outlet it is plugged into and that any fuses on the unit test good.
Ricky
Old 08-08-2009, 06:24 PM   #19
wannaroam's Avatar
Images: 36
Can I ask: the outlet has to be wired correctly (correct polarity) since anything else plugged into it works.
Right??
Old 08-08-2009, 07:26 PM   #20
richinny's Avatar
2011 34' Classic
NO, NOT CORRECT. many things can work with reversed polarity, others will not work. the circuit tester can be a lifesaver which is why everyone will tell you to get one and use it! when you have a problem, you have to verify everything step by step.
Ricky
Old 08-09-2009, 11:43 AM   #21
wannaroam's Avatar
Images: 36
We do have a circuit tester (and have used it). He hasn't put the converter back into the AS yet.
If he plugs the converter into the wall at the house, and checks it with the circuit tester on the positive and negative of the converter should it show some voltage? Because it doesn't if it should.
I apologize for not getting pix yet; am having some trouble with my digital camera too. (And with getting hubby to put unit back in the AS)
Old 08-09-2009, 12:21 PM   #22
richinny's Avatar
2011 34' Classic
yes, you should have 12v dc output (or a little higher) observe the correct polarity on the hookup. those units might have internal fuses that should be checked.
Ricky
Old 08-09-2009, 01:26 PM   #23
wannaroam's Avatar
Images: 36
We did check internal fuses; that was one of the original problems - it kept blowing fuses inside the converter itself.
And again - it shows no voltage when plugged in inside the house.
Old 08-09-2009, 01:39 PM   #24
richinny's Avatar
2011 34' Classic
no voltage is not good. did it trip the house gfci?
Ricky
Old 08-09-2009, 02:40 PM   #25
wannaroam's Avatar
Images: 36
Nope - it did nothing but sit there and look at us.
Which is just what it did when he checked it in the trailer too.
Old 08-09-2009, 05:21 PM   #26
richinny's Avatar
2011 34' Classic
ship it out for repair.
Ricky
Old 08-09-2009, 05:32 PM   #27
wannaroam's Avatar
Images: 36
Ok; I guess we will do that. Thanks to everyone who helped answer questions for us.
Old 07-06-2015, 02:03 PM   #28
1990 33' Land Yacht
Chance , Maryland
have a 1990 airstream landyacht with energenius eg3000 series the breaker with the white test button has blown, what do i do, and where do i get a new one?
bjkayla is offline   Reply With Quote
power jack keeps blowing fuse? jlemmons Jacks, Stabilizers, Lifting and Leveling 6 08-01-2009 10:38 AM
Fuse blowing and sparking! Lily&Me Batteries, Univolts, Converters & Inverters 7 07-27-2009 01:18 PM
Fuse #1 keeps blowing Z33 Electrical - Systems, Generators, Batteries & Solar 12 12-16-2006 08:43 AM
Parking light fuse blowing andyfuson Tow Vehicles 7 07-26-2006 05:54 PM
Power converter "fuse" rfield54 1997 - 2004 Bambi 0 09-02-2003 02:26 PM
