Old 08-13-2014, 08:47 PM   #1
Arcticfox's Avatar
2013 28' Flying Cloud
Central , Canada
Converter Fan noise on 2013 FC....
Greetings Folks:
This will be (I'm sure) a really stupid question, but one I need to ask anyway....
Today for the first time - I had a fan come on in the area of my converter. Is that normal? (brown plate under "L-shaped sofa in 28' Flying cloud- rear bedroom)
I tried to do a search on this topic and it does look like the converters have fans - I'm just surprised that this is the first time I've heard it. So does this fan come on a lot when plugged into house power or an I missing something here? As you would have gleamed from my above question I'm new to the airstream and really am just now still trying to figure out what all the systems do.
If someone can give me an education on this - that would be GREAT!
Doug
Trying to use my camera to create memories - not photographs!
Arcticfox is offline   Reply With Quote
Old 08-13-2014, 09:02 PM   #2
Landrum's Avatar
2014 25' FB International
Little Rock , Arkansas
Yep it's normal. At least I hope so because that cooling fan runs on our AS as well(it also ran on our last AS). It should run whenever you are plugged in.
Landrum is offline   Reply With Quote
Old 08-13-2014, 09:03 PM   #3
Airstream Driver
PeterH-Airstreamer's Avatar
1997 30' Excella
Images: 51
Was it a hot day in combination with you using several 12 volt lights and/or 12v systems. If the answer is yes, that is the way the converters are supposed to function. A thermal switch will turn the fan on to cool it down.
If it was a cold day and you were not using any 12V systems, you may have a shorted battery that is overheating to the point of causing a dangerous situation that should be looked at immediately.
1996 Airstream B190
1987 29' Sovereign Trailer
1997 30' Excella Trailer
AIR #13
PeterH-Airstreamer is offline   Reply With Quote
Old 08-13-2014, 09:43 PM   #4
Arcticfox's Avatar
Central , Canada
Thanks folks - good to hear what i'm hearing seems normal! At least i'm not going to burn the place down or something
Thanks again
Doug
Refrig fan noise FIXED...really dtbw Refrigerators 264 01-31-2018 05:15 AM
Motor noise vs fan noise vs overdrive question SebasSF Mechanics Corner - Engines, Transmission & More... 25 12-15-2013 11:18 AM
Help converter making funny noise! purman Batteries, Univolts, Converters & Inverters 5 07-15-2012 09:15 AM
Upgrading converter due to fan noise Jammer Batteries, Univolts, Converters & Inverters 20 07-05-2011 11:04 AM
Converter fan noise - parallax vs others Jammer Batteries, Univolts, Converters & Inverters 4 05-11-2010 07:59 PM
