Old 07-29-2011, 02:01 PM   #15
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
Might want to check the internal fuses on the output of the charger. Their web site has manuals if you need them: Truecharge Battery Charger | Truecharge2 20A, 40A, 60A | Xantrex
Chris
Old 07-29-2011, 02:56 PM   #16
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
Have you tested the batteries? Did you charge them monthly during the winter? If not they may be dead, but should come back with a charger. Maybe the converter is ok, but for some reason isn't charging the batteries. If you have a battery charger, disconnect them from the trailer and charge them that way and see what happens—check for voltage—and then reconnect them and try things.
Gene
Intellipower Converter wlanford Batteries, Univolts, Converters & Inverters 24 07-21-2011 10:27 PM
F-150 torque converter lock-up woes... Dave Park Tow Vehicles 30 06-09-2011 08:27 AM
Converter Question henw Batteries, Univolts, Converters & Inverters 5 05-10-2011 06:55 AM
univolt converter switch position? godaddy64 Electrical - Systems, Generators, Batteries & Solar 8 02-25-2011 12:17 PM
