Old 09-19-2019, 10:51 AM   #1
richw46's Avatar
Lexington , Kentucky
Converter connection to battery
Opinions on these questions/answers. My AS is in storage and I'm too lazy to go over in this heat and find them out myself.
In earlier versions of AS, if the Use/Store is in Store, even with shore power the batteries won't charge. They will charge only in Use and on shore power.
A. ON SHORE POWER
Q1. If there is no connection for charging in Store, is the voltage reading at the batteries different from the voltage reading at the red and white wires on the converter? (I think yes)
Q2. If the switch is in Use position, is the voltage reading at the batteries and at the red and white wires on the converter the same? (I think yes)
B. OFF SHORE POWER
Q1. If there is no connection for charging in Store, is the voltage reading at the red and white wires on the converter zero? (I think yes)
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE
richw46 is offline   Reply With Quote
Battery converter not charging battery airstreamz Electrical - Systems, Generators, Batteries & Solar 5 09-24-2014 03:55 PM
Strange connection from inverter to battery mikextr Electrical - Systems, Generators, Batteries & Solar 1 05-28-2014 08:19 AM
Battery Connection / Inline Plug Andreasen Batteries, Univolts, Converters & Inverters 6 05-12-2010 12:46 PM
plug-in battery connection racoco 1974 - 1979 Sovereign 3 10-22-2006 09:17 PM
puzzled by fuse at battery connection Tin Tortuga Electrical - Systems, Generators, Batteries & Solar 2 03-25-2005 03:13 PM
